Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,140
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
Re: What is the exact meaning of \"rated engine speed\"?
I don't know who resurected this zombie but rated speed is the speed at which the the engine develops it's "rated horsepower". If the manufactuer claims that an engine is rated at 90 hp at 2400 rpm. That's the rated hp at the rated rpm. ndividual engine will often produce more that the retaed hp but this rating will be selected so that the worst engine produced will not be below this number.
Often times there is rating given for max pto hp and that is for the max ppto ower available at the engine rpm that gives 540 rpm OR 1000 rpm at the pto which ever rpm (or both) it is rated for.
Max torque is the peak of the torque curve and is much lower rpm than rated rpm. The torque curve vs rpm is not generally "flat" but it is not as "peaky" as the HP vs rpm curve.
As stated above, running the engine from low idle to high idle can run through these various rated speeds but the engine is not producing max power at rated speed under these conditions. The only loads on the the engine at these conditions are the auxilliary loads ( hydraulic loads, alternators, etc) and they are much smaller than rated loads.
What generally limits max power on a diesel at any rpm is visible smoke (the point at which no more fuel can be burned in the cylinder because the charge has run out of oxygen). It'a usually indicated by a certain allowable Smoke Number. When you see a curve of HP vs rpm your looking at the locus of points where whatever the allowable smoke number is, is occuring under load.
Except for not making it clear that torque vs RPM assumes a load. Running an engine at any RPM under no load (clutch depressed or in neutral) and you are not developing squat for HP or torque.
Pat
