What is the exact name for this controler?
   / What is the exact name for this controler? #1
8404
North Mississippi
Cub Cadet 8404 or DK 40 Kioti
What is the exact name of this part? it has three possitions up, down and center. I want to add anouther control on the side of this one so i can run a hydraulic powered winch on the front of the tractor, do i have to buy only from the manufacturor or are these parts all the same for all tractors?.
   / What is the exact name for this controler? #2
Looks like a stack Hyd. control valve, spring center to me. Mfg unknow and why the A and B ports lines are so tall is also a ?, maybe the easy way to clear something. If you can find out the Mfg. you should be able to add another valve.
   / What is the exact name for this controler? #3
So what is this present valve controlling? a 5 position valve is pretty rare.....;)
   / What is the exact name for this controler? #4
Looks like a rear hydraulic control valve.
A second set from Kioti should fit your machine. I think they run around $225 -$250 area for a second valve kit and it just bolts/stacks onto the existing valve.
Yes it a rear remote for my Kioti tractor, but there seems to be so many names for it, single spool, double spool, one way, two way valve, Power beoynd valve???. for instants i need the 2nd remote to run a hydraulic winch so i need to use it just like the original valve, to run the winch in and out but i also need to limmit the pressure to 1500lbs and the flow to 4gpm. I was going to try and buy this part online "EBAY" but its impossible to know if anything that they are selling will fit my tractor. So Im going to call the Wallace tractor place since ive already read that he can get me what i need and does a lot of selling to Tractor by NEt members. Its confussing for some of the Kioti dealers that my Cub Cadet is a KIOTI.
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
2013 Kia Soul Hatchback (A55853)
2013 Kia Soul...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2012 Case IH 1250 24-Row Early Riser Planter (A53485)
2012 Case IH 1250...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
