what is the expected service life of a GX270 Honda
   / what is the expected service life of a GX270 Honda
I know, it sounds high, and I'd be better off with a bigger feeding system but it's been mixing and feeding feed to 40 cows all those years! One thing I'll say and that's that it seldom gets run at the 3600rpm max, it's mostly running in that 2500rpm "sweet" spot or idling while loading
   / what is the expected service life of a GX270 Honda #12
That's another key to long life; not running it at 100% of rated RPM. As long as it's getting hot enough during use to keep the oil condensation-free, it should keep running well for a really long time.
   / what is the expected service life of a GX270 Honda #13
it will last many thousands of hours ala oil is changed regularly and you adjust the valves. ive had good luck with the honda gx motors lasting me years.i never run synthetic ever. straight 30w oil only in my 13hp ground blower and generator. I run my equipment at 3600 rpms constantly.
Well guys, sounds like I can keep going with it for awhile yet! Just keep it serviced and tuned up! I have wondered about maybe setting the valves sometime but still never have. Starts and runs fine so I figure the valve seats must wear to compensate for and tapper wear or something
   / what is the expected service life of a GX270 Honda #15
go w/ethanol free fuel. full syn oil, but would hold to 150 hr change intervals, not 300. it's a small engine. does it have an oil filter, or just splash oil sump?
also agree w/above to adj valves after 1st 50-100 hrs. check online for your model
Honda Small Engine Intake and Exhaust Valve Clearances
Ya I'm using ethanol free gas and Syn oil. Since it only needs 1 quart of oil and doesn't have a filter changing it is the only way to get contaminants out so that's likely why they spec relatively early oil changes
   / what is the expected service life of a GX270 Honda #17
That’s a lot of hours. Years ago we had a machine powered by those engines. They were mounted on a trailer and powered a hydraulic pump. The trailer was pulled around off-road and the engine was running wide open 10 hours a day in very dusty conditions. I would say on average though it was only used 10-15 days a month but they were hard dusty days. In my 9 years of working with this setup I think we went through three or four engines. The oil was changed regularly and checked daily I think the dust and running while bouncing around on a trailer and WOT conditions got them.
In you scenario with over 8000 hours I would say you are on borrowed time. It may last a lot longer it may not. Regardless it sounds like it is an important engine for you so I would recommend buying a spare and having it on hand for when the day comes that she let’s go so you can swap it out and keep going. Swapping the engines is quick it is the finding them on short notice that is tough. I can tell you a couple stories of engines failing on us on holiday weekends and driving across several states to pick up a replacement so a crew of six guys wasn’t sitting around unable to work.
   / what is the expected service life of a GX270 Honda #18
How is the compression, if okay you may not need to adjust the valves. I would not worry so much about 8100 hours given the oil changes that you have done.
Hi, sounds like we think along the same lines, I was at an auction and got a pretty good deal on a Subaru engine new in the box that I'm hoping I could pop on if need be! Not that I expect it to last like the Honda but I have no experience with those!
Thanks!
I haven't done a compression test on it, but if you pull slowly on the starter rope it does leakdown and let it turn slowly on the compression stroke but still starts good considering the hours
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
1999 INTERNATIONAL 4700 24FT BOX TRUCK (A58017)
1999 INTERNATIONAL...
10222 (A56858)
10222 (A56858)
flatbed trailer 24ft (A56857)
flatbed trailer...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
