What is the quarter inch diameter light in the Ford model 1710 4X4 dashboard
   / What is the quarter inch diameter light in the Ford model 1710 4X4 dashboard #11
The wiring diagram shows it as a charging light. You don't have an ammeter gauge so that would be logical.
Thanks to all for your help. Definitely appears to be an add-on, not factory.
   / What is the quarter inch diameter light in the Ford model 1710 4X4 dashboard #13
Charge lamp and low oil pressure indicator are integrated with the tach/hour meter.
   / What is the quarter inch diameter light in the Ford model 1710 4X4 dashboard #14
Since you have that heat coil (‘cold start aid’) on the left side of your dash u less it was added to that circuit as a user add on, I would doubt it to be for the glow plug circuit.
Most 3 wire bulbs for a warning light will have a ground wires (the bulb will be in the circuit wire and use 2 contacts and the 3 a ground) so if it was added to the glow plug, the ground would allow a completed path for the bulb to light, the power input line coming from a timer relay (if equipped) and then the last wire to the glow plugs to deliver the power to them.
You need to chase those 2 wires present to figure out where they go!
It could be for any type of lite feedback.
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
Toro Sprayer Cart (A50324)
Toro Sprayer Cart...
2239 (A51244)
2239 (A51244)
UNUSED FUTURE 24" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 24"...
