What is this hydraulic thingy
   / What is this hydraulic thingy #11
Although I agree orientation of restrictor disk is important as to which direction oil is restricted. I see no way the disk can wedge in a port or hose because the disk has a larger diameter than hose & valve port is machined to limit disk penetration. On many applications restrictor disk is fitted between hyd coupler/tip and hose
Not wedging is true IF the port is made to a size per a standard. I have seen where the predrill diameter on the port was the same as the minor diameter of the threads. These discs won't work then.
2024 JOHN DEERE 6135E LOT IDENTIFIER 244 (A53084)
2024 JOHN DEERE...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2023 JACTO ARBUS-1000 LOT IDENTIFIER 68 (A53084)
2023 JACTO...
LOOK! (A53342)
LOOK! (A53342)
