What kind a radio for my Kubota?
   / What kind a radio for my Kubota? #21
Thanks, yes, I did use a press drill for stability and small buffing dick with 120 grit sand paper. After that, a coat of clear finishes the job just right.
   / What kind a radio for my Kubota? #22
Going to resurrect this thread.. I found a good fit for my upcoming 3540 cab.. This should work nice.
Sony DSX-S100 Digital media receiver - Hands-on Research at Crutchfield.com
Ipod goes INSIDE and plugs in via USB
can't wait. Trouble is, I'll get the tractor in April.. and will just be dubbing around with driveway and sickle mower on my ditches. SNOW is where it's at for seat time.
   / What kind a radio for my Kubota? #23
Just a suggestion here, but I would put in a marine radio, or one they use on boats,many have all the plug ins for ipods and jsut about anything else, made by name brand manufactures, but they are water resistant/ waterproof, many also have a case which incloses the radio case, and combine a hinged cover that flipsdown over the face plate. That would keep out a lot of dust and such as well and give you a cleaner installation if it in a cab up in the corner and such.
Cabelas has some good prices, like 129.00 and up depending on what ya want. I was thinking about one for my CJ-5, at least the face plate cover would be nice.
Here is a jenson from there site for 160.00
s7_021537_999_01
   / What kind a radio for my Kubota? #24
cd players are being changed out to. Ipod holders that fit inside the radio itself.
as far as radio not fully going back in. most likely you have a jumbo of wires that is causing radio to not go all the way back in. ""or"" the antenna cable is causing things to hang up and not fully go back in. (you can get 90 degree adapters). also some times it requires a very slim long screw driver to push wires back down into an area for the radios to fully go back into the area.
radio is on the list for the 555c. after the full hydraulic change / flushing and getting lens covers for the rear "tail,flasher,turn single" lights.
for the blazer, last radio went out, and just checked, walmart, bestbuy, circuit city, google and a couple other stores that have websites. and just bought the cheapest that i liked. though i think i had to deal with Amps for the speakers. i am think i went for 30 amps per each speaker. total speakers = 4. usb for songs or ipod or other MP3 player. would work on it.
i did go with one that had better folder searching of songs and how it moved across different artists/albums.
Sunflower Yard Decoration (A55758)
Sunflower Yard...
1977 Ford F-100 Ext. Cab Pickup Truck (A53422)
1977 Ford F-100...
Toro Groundsmaster 4500D 4WD 5-Deck Fairway Mower (A55787)
Toro Groundsmaster...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
Auger (A53316)
Auger (A53316)
Sawmill YC-26G W/ Gas Motor (A47477)
Sawmill YC-26G W/...
