What kind of tool to lay landscape light wiring?
   / What kind of tool to lay landscape light wiring? #11
Good point about the depth Bob. I don't think dog wire is buried very deeply though.
I at some point plan to make a special scarifier longer, as stated, to bury deeply.
THKS.
ron
   / What kind of tool to lay landscape light wiring? #12
My son bought a used lawn edger for $25.00 to install his dog fence.
It cuts a 2” deep x ½” wide trench.
Works great! You could probably rent one as well.
I am going to have to find out what a "subsoiler" is. I am new to this whole thing.
This makes alot of sense to me. The only problem is, I just bought my tractor, FEL, mower deck, ballast box, and lawn roller. I need something very inexpensive. When I do get a box blade (for our gravel driveway), I want to get a decent one, and that isn't going to happen for at least two years.
Someone else mentioned this, but I thought I'd clarify. I am only going to be laying low voltage, so depth isn't a legal issue. I am planning to bury it about 4" deep, mostly so the dogs don't dig it up.
Hey, thanks for all the details. This is a good, and cheap, idea. I'll copy this information to use, once I find out what a subsoiler is. Thanks.
Oops, I didn't think to look at your attachment. That is PERFECT!
This looks like a good candidate (useful for cutting across gravel driveway too).
   / What kind of tool to lay landscape light wiring? #18
Uh, you might have trouble pulling it across a hardpacked drive. Especially with that wide moldboard. A chisel point type deal would pull easier and easy to fashion.
If you can't buy a subsoiler now, you could bolt a shank to the end plate of you FEL bucket. I would CAUTION that if you do this, you go very slowly as you could catch a rock or something and bend your FEL. I would not recommend this approach, but it would beat using a shovel..........
ron
Thanks for the tips. I probably wouldn't want to bolt something to the FEL for the reason you mentioned. I was thinking a couple passes with that subsoiler might work, if the gravel was wet, and I were willing to take a few passes at it. If it doesn't, and I end up using a shovel to dig across the driveway, it would just be two paths, ten feet each, and I plan on running several hundred feet of cable, so that's not too bad.
   / What kind of tool to lay landscape light wiring? #20
This is what you are looking for, not a middle buster like in your link. Your BX should be able to pull something like this without too much difficulty. (maybe a smaller version, but this is the type of thing.)
HYDREMA 922HM 6X6 OFF ROAD DUMP TRUCK (A52706)
HYDREMA 922HM 6X6...
2011 ELITE TRAILER 20 T/A GOOSENECK (A55745)
2011 ELITE TRAILER...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2006 KENWORTH (INOPERABLE)T800 (A55745)
2006 KENWORTH...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
