What Makes a Z-Turn Better ?
   / What Makes a Z-Turn Better ? #11
</font><font color="blue" class="small">( the seat is going to be one thing to look at. Whether or not it is suspension)</font>
<font color="red"> My Hustler FasTrac without a suspension seat rides fine on smooth terrain or at reasonable speeds. On rough terrain I could more comfortably cut with a suspension seat at higher speeds, but the cut quality would stink! If I'm bouncing, it means I'm going too fast, and the bouncing deck will be giving me a quick poor cut!! So I let my butt decide what is the best speed for my comfort AND a quality cut! </font>
/forums/images/graemlins/grin.gif
   / What Makes a Z-Turn Better ? #12
The Country Clipper ZTR deck is suspended from the articulating front end which actually makes it follow the ground much better than a solid axle. Regardless of the amount of weight on the rearend of these ZTR's without an articulating front-end they just don't stick as well on hills as one with an articulating front-end.
KO
   / What Makes a Z-Turn Better ? #13
Just to present an opposing viewpoint, I just sold a ZTR (older) and ended up replacing it with a JD 455 with a 60" deck instead of the new ZTR I expected to buy. The old Ransomes I sold had a built-in collector that could not be removed or by-passed. I am mowing around an acre, so that amount of collected grass turns into a big pile pretty quickly. I blamed the age of the machine for the skid marks I made on every turn, no matter how careful I was. Following the contour of a curved sidewalk that was on a slight side slope was difficult without (again) leaving skid marks. One side always seemed to be driving slightly faster than the other, making constant adjustments necessary.
I thought all my problems would be solved by moving to a newer machine with an advanced drive system. I drove an ExMark and a JD. In both, I found the same thing. I had to constantly adjust the control handles. I couldn't just relax and expect the machine to travel in a straight line.
The 455 might take a little longer to get the job done, but it seems perfectly matched to the contours of my walks and drives, leaves a beautiful cut (much better than the old Ransomes), lets me daydream a little while I'm working (doesn't require constant attention), doesn't leave skid marks at every turn, and has the added benefit of being a tractor that can accept other implements and has auxiliary hydraulics.
   / What Makes a Z-Turn Better ? #14
Whats a JD 455? I went to the website and saw no such mower. I suspect its been replaced.
   / What Makes a Z-Turn Better ? #15
Sorry, the 455 is a lawn and garden tractor. Until the current "X" series came out, it was the top of the line JD-LGT. It is powered by a 22HP Yanmar diesel engine, has two hydraulic circuits, and has optional 540 RPM PTO and Cat 0 or Cat 1 three point hitch available. If you're a Kubota guy, it is about the size of a BX2300, but without 4WD and the PTO and 3pt are options. It was discontinued around 2001(?) and replaced by the X495. I bought mine off eBay for $4300.
   / What Makes a Z-Turn Better ? #16
Main reason for a ZTR is you can pretty much go full speed and also get closer to things because the deck is right out front where you can see and gauge where it is. Went from Sears tractor mowers to a Scag on 5 acres in NJ. Took 5-7 hours on the tractors and 3 hours and 15 minutes on the Scag. Could go around trees at top speed (sometimes on 2 wheels) and not leave any grass uncut.
They're also worlds better to maintain. The Scag deck had a crank to raise the 3-bladed deck. All the blades were held on by through-bolts. I could raise and have the blades off in about 5 minutes, took them home for sharpening and took about 5 minutes putting them back on.
Used the Scag also to chop up leaves from the numerous oak trees on the property. Just discharged inward intil it started to choke down and then turned around for a couple rounds. Then went back to discharging inward. Surely beat the heck out of riding around on those tractors with a roaring engine behind the seat sucking off the deck and discharging into a tented cart behind that had to be emptied later.
Ralph
   / What Makes a Z-Turn Better ? #17
The advantages of the ZTR are IMO high ground speed, and agility. However their are other things to consider.
Mandatory 2 hand operation on most models: No sipping, smoking, waving, etc...while you mow. (don't laugh that stuff is important to some folks)
Rough ground will limit your groundspeed to tractor levels thus negating the speed advantage.
"Work". Most (not all!) ZTR's are unsuitable for any task beyond mowing or pulling a lightweight cart.
Slopes. With most models hills are tricky. If you mow along a slope...holding a straight line can be awkward because the front castor wheels want to follow the law....the law of gravity! This means that you have to mow up and down even mild slopes. And for the record on some units you best be careful coming down the hill...some will skid.
Let's eat grass! On some units you will get literally covered in grass...not all mind you but some.
What this all boils down to is that ZTR's are great units just like tractors...but also like tractors they have limitations and quirks that take getting used to...
I post 3 buying tips fairly regular on another site and they seem to work...i'll post em' here for you...keep in mind that these tips are just my opinions! :)
Slam
Here they are once again folks...Slammers famous three point checklist for mower buying success...
1. Carefully evaluate the size mower you need and buy at least one size larger.
2. NEVER buy a mower from ANYPLACE that will not let you test drive it or at least a similar model. Ergonomics are just as important as performance and capability.(Vitally important!)
3. DO NOT base your purchase on price or brand name alone! Do proper research and find all of the available models that fit your criteria and haggle, save, or trade to get the right equipment for the job. Do not compromise!
If you follow these three tips you will end up a happy camper with just the right unit for the job. If you disregard this advice your gonna end up with One or the other of the following problems:
A. Buyers remorse. Stuck with a piece of junk or simply a unit inadequate for the task at hand.
Or..
B. A teed off spouse when you start shopping for another tractor just 3 - 6 months down the road because you did'nt buy the right unit in the first place.
Now go forth and shop and try and have fun!
   / What Makes a Z-Turn Better ? #18
Your advice sounds good to me ,
Especially since your holding that BIG GUN!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / What Makes a Z-Turn Better ? #19
</font><font color="blue" class="small">( Your advice sounds good to me ,
Especially since your holding that BIG GUN!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
BWAHAHAHAHA!!!
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2005 Ford E350 XLT SD Passenger Van (A53117)
2005 Ford E350 XLT...
Dell Desktops Computers (A51695)
Dell Desktops...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A53473)
3-Point Hitch Root...
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
