What mower will cut a steep, rocky grass and clover patch?
   / What mower will cut a steep, rocky grass and clover patch? #1
dweebil
Rhinebeck, NY
Ford 2120
Hello, I have a steep, uneven and rocky food plot planted with white clover. It needs mowing once or twice a year. I believe a finish mower may get damaged and a brush hog may not do the job. Any suggestions?
Thanks.
   / What mower will cut a steep, rocky grass and clover patch? #2
I made a slasher out of an old brush hog. It tolerates rocks well and cuts down every living thing I've run over
   / What mower will cut a steep, rocky grass and clover patch? #3
Have you looked at an offset flail mower with hammers?
   / What mower will cut a steep, rocky grass and clover patch? #4
I've got a nearby neighbor with a wet land. Twice a year, she hires someone to cut it all down with a string trimmer/ bladed weed wacker.
It's about three acres all told.
Good work if you can get it.
   / What mower will cut a steep, rocky grass and clover patch? #5
You could take the blades off the brush hog and replace
with a thin wire cable
willy
Chains. Interesting idea. Thanks
Right. Hard work if doing it by hand.
   / What mower will cut a steep, rocky grass and clover patch? #10
What about goat rentals?
2017 BOBCAT T595 SKID STEER (A52709)
2017 BOBCAT T595...
2011 TROXELL 130BBL STEEL (A58214)
2011 TROXELL...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
