What oil weight
   / What oil weight #11
A quart of oil - 32 ounces - is a fluid measure - volume. A pound - 16 ounces - weight.
A quart of water weighs about two pounds.
Gasoline weighs about a pound and a half per quart.
Lube oil is somewhere in between.
Fluid ounces have nothing to do with weight.
   / What oil weight #12
Correct you are fluid ounces have nothing to do with weight. So why is the viscosity of oil referred to as weight ? Just curious, anyone know ?
   / What oil weight #13
A quart of oil is short of 2 pounds, because it is lower than the specific gravity of water.
Don't know why oil viscosity is called a "weight". I would have called it "wait". In the winter, in can be a long wait for a higher viscosity oil to flow. Some won't flow at all.
Ralph
   / What oil weight #14
More stuff than everyone doesn't need to know (from a Web page googled oil weight):
The way oil viscosity is measured is with a Saybolt orifice viscometer, which is basically a cup surrounded by a water bath which keeps the temperature of the oil sample constant. There is a plugged opening in the bottom of the cup, which is opened when the oil is at the proper temperature. The oil is captured in a 60ml flask and the amount of time required to fill the flask is recorded.
A SAE30 oil takes 58-70 seconds to fill the flask at 210F,
an SAE40 oil takes 70-85 seconds, and
an SAE50 oil takes 85-110 seconds.
There is also a test for low-temperature viscosity that is designated by a "W" suffix on the SAE viscosity rating.
A SAE5W oil takes less than 6000 seconds to fill the flask at 0F.
An SAE10W oil takes 6000-12000 seconds, and
an SAE20W takes 12000-48000 seconds.
I'd assume that the winter oil testing leaves the test engineers with plenty of time to relax while waiting for the test to conclude! Ah, the life of a petroleum engineer!
A "multiviscosity" oil is simply an oil that has been rated using both tests. Nothing magic about it, except that sometimes the composition of the oil has been tweaked to flatten the viscosity-temperature curve.
Note that a SAE30 oil and a SAE30W oil are not the same thing, as they are measured using different tests.
   / What oil weight
BXMMCC very interesting Larry thanks
   / What oil weight #17
All of the oil viscosity tests seem to deal with temp/volume/time. Where does the weight come in? Might have missed something though.
   / What oil weight #18
From the howstuffworks webpage:
The weights given on oils are arbitrary numbers assigned by the S.A.E. (Society of Automotive Engineers). These numbers correspond to "real" viscosity, as measured by several accepted techniques. These measurements are taken at specific temperatures. Oils that fall into a certain range are designated 5, 10, 20, 30, 40, 50 by the S.A.E. The W means the oil meets specifications for viscosity at 0 F and is therefore suitable for Winter use.
   / What oil weight #19
Thanks for the expanation on the "weight" thing. I sort of assumed that from scanning the article, but you know about assumptions /forums/images/graemlins/smile.gif
   / What oil weight #20
</font><font color="blue" class="small">( And for those who really are curious:
Oil weight )</font>
Very interesting. Thanks for the link.
CAT 973 Crawler Loader (A47477)
CAT 973 Crawler...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A55218)
2010 Ford F550...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2000 Ford F-150...
2005 Freightliner M2 106 Box Truck (A52377)
2005 Freightliner...
