What Older Reliable Tractor for Small Farm?
   / What Older Reliable Tractor for Small Farm? #31
Welcome to the forum birdo.
The farmall 350 is a great tractor. Independent PTO and roughly 45 hp. If you are running a smaller baler like a JD 14/24T or New holland Hayliner 68 it can easily handle it. 6' bush hog would be no problem nor running a sickle or drum mower for your hay cutting.
As for wrenching on the tractor I don't want to make sound over simplistic but they are not too difficult to work on especially basic maintenance you got fuel, compression and points thats it. None of these electrical dead man switches, sensors, or emission garbage like these new tractors that can go wrong. If its not running right 90% it's fuel related on old gassers. The other is spark but even that is few and far between. Major parts are still readily available and in a lot of cases I've come to find out cheaper because they don't have to come from OEM.
As for the bucket, I would look putting it on your smaller tractor and keep it off the old iron. The one weak point on these tractors is usually the front spindle because they were never originally designed for loaders and if one broke you would probably have to find a good used one or someone that is a **** good welder.
The 2030 is a considerably larger tractor than the farmall 350 and I would just ballpark it but probably double in cost. I would definitely go diesel with that if you decide to go that route. With that tractor you could run a mower/conditioner and a round baler. JD's are good tractors but I am always amazed at what people are asking for them. The one plus about JD I will admit is their parts inventory. Go to JDparts.com and you can still find certain parts for tractors and implements they made back in the early 50's. The 2030 could handle a loader without an issue I would guess. It's an early 70's tractor and by than loaders were pretty common if not a factory option by than.
   / What Older Reliable Tractor for Small Farm? #32
This is such helpful information. I end up using a loader quite a bit. That's an important part of a heavy machine for me. I actually use horses (the kind with four legs) to do a lot. And horses don't come with a front end loader. ; ) I'm hoping to rig up a bale grapple for stacking small bales. We have a nice old NH 268 baler. Similar to the 24T.
unless they are split i wouldn't immediately repalce them. you might get 10ys on them tires. I'm rolling rubber that looks alot worse and have looked that bad for 15 ys.. :)
Thanks for the heads up. Still looking. I was out of town and was not able to get up with the guy in time. It's not listed anymore so I guess I need to keep looking around.
   / What Older Reliable Tractor for Small Farm? #35
That is a good looking machine.
I thought so too. The Ford 801/901 series is right at the top of my favorite list. There is a very clean 951 diesel locally that I really want to sneak into the barn, but the wife might notice :(
   / What Older Reliable Tractor for Small Farm? #36
go for the sneak. what's the worst that could happen! ;)
   / What Older Reliable Tractor for Small Farm? #38
i would!
   / What Older Reliable Tractor for Small Farm? #39
once you have enough.. it's hard to tell them apart if you collect the same models. :)
   / What Older Reliable Tractor for Small Farm? #40
I nearly bought a 961 a few years ago. Test drove it. Seemed to work OK. Then I tried to shift the pto on/off via the 2-stage clutch. Problems. Could have been a simple adjustment would have fixed it. Or maybe I'd have to split the tractor and replace the clutch. Couldn't get the price negotiated down to my comfort level based on the test drive so I passed. Nice tractor--I collect tractors with bull gear drive. Keeping my eyes out for another 900 series tractor.
Good luck.
7021 (A50322)
7021 (A50322)
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2000 FORD E350 CUTAWAY BOX TRUCK (A54313)
2000 FORD E350...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2003 Mack CH613 T/A Day Cab Truck Tractor (A52377)
2003 Mack CH613...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A54811)
1996 JLG Commander...
