Snowblower What PTO shaft for snowblower
   / What PTO shaft for snowblower #1
smokydune
Greetings everyone, I'm buying a used 72 inch rear mount blower for my kubota 3130. Blower does not come with PTO shaft. Private seller. Besides minimum and maximum lengths, what do I need to know? Any help would be appreciated. smoky
   / What PTO shaft for snowblower #2
You just need to know the length between your PTO shaft and the blower shaft, the diameter of the blower shaft (which usually has a keyway), and how many splines on your PTO.
The tractor has a 1 3/8" 6 spline, the blower is unknown as I don't have it yet. Any class or size I should consider other than length of course, smoky
   / What PTO shaft for snowblower #4
Seems your spline is standard. You wont know what length you need until you can hook it to the tractor. Most blowers I've seen have a 1" shaft with a keyway but it depends on make and size of blower. 3pt is probably a cat1.
   / What PTO shaft for snowblower #5
The most cost effective shaft you will find will be metric. Buy at least a class 4 shaft; a class 5 will be stronger. Determine if you need shearbolt protection built in the shaft, or if it is provided elsewhere on the machine. Many blowers have the fan protection in the PTO shaft and auger protection in the auger driveshaft (gearbox output shaft). If the retailer can't tell you what class of driveline he is selling, find another retailer.
Thanks to all that have provided their help. This wednesday I'll be picking it up. I'm sure I'll have it up and running before long. I e'mailed the manufacturer (Smyth welding) but no response yet. Thanks again, nice forum, smoky
LOT: (4) Pairs of Tire Chains, Fits Tire Sizes: 11R-22.5, 285/75-22.5, 295/75-22.5, 275/80-24.5, ... (A59076)
LOT: (4) Pairs of...
406 (A52706)
406 (A52706)
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
WOODS 1033674 SUBFRAME KIT (A58376)
WOODS 1033674...
VALMAR AIRFLO 8600 PULL TYPE FERTILIZER SPREADER (A58375)
VALMAR AIRFLO 8600...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
