What rotary cutter are you running on your 5700?
   / What rotary cutter are you running on your 5700? #1
bigtater
Southeast, TN
bota 5700
I'm in the market for a rotary cutter and I'm wondering what size and type other people are using. I'm torn between a heavy duty 6' or maybe try going with a 7 footer.
   / What rotary cutter are you running on your 5700? #2
Last summer I purchased a Brown 472 heavy duty rotary cutter for my new 4630. While I do not have a great deal of experience with rotary cutters, I can attest to the toughness of the Brown. I mowed approx. 40 acres of ex-christmas tree fields. It ground up the old stumps and left over scrub fir with little effort. I got hung up on two different rocks that I could not lift the cutter off of with the 3 pt. hitch and ended up driving off them. This only left a small ripple on the deck of the cutter, although it did a number on my blades. While clearing some grown up trails, I cut lots of 2-3 poplar and birch roughly 12 ft. tall without a problem. This cutter is tough! I would recommend the chain guards on both ends (this leaves the fields looking like they were hayed and works great when backing over the small saplings). I found the 6ft. to be plenty large for maneuvering around the larger trees left in the field and could not imagine needing a larger one, even on a 5700. Mine covered my tracks plus about 4" extra beyond the rear tires. Good luck with your purchase.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2020 DRAGON ESP...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
