What should I plant?
   / What should I plant? #11
You need to contact a county agricultural agent and get his/her input.
Florida has "Green Belt" classification for ag property.
Thanks everyone, I have a lot to look in to and and some real good places to start. I'll keep the thread active while I look in to everything.
   / What should I plant? #13
City Farmer said:
He's not doing any improvements, the run off ditches have trees growing in them and the main trail is all rutted up. Instead of putting in a culvert, he just pushed dirt into the run off ditch to get between the fields. I don't know if he's putting anything back into the ground but I doubt it. It's time for him to go, I think I'll try hay. I can tell the county its planted even if I don't harvest it.
Sound like a ground raper or just figured he would be out so he didn't care. He made a lot of money off of depriving your land.
   / What should I plant? #14
Yikes, that's too bad. I'd put him on the next train, errr tractor outta there.
   / What should I plant? #15
Yikes! Agreed that the renter needs to leave. There are good renters out there, but this guy doesn't sound like one. Our renter has been fantastic! He's graded ditches, maintained the culverts, keeps the fields looking like a million bucks, and even removed a spongy grove of junk trees that has been creating problems; He's even voluntarily raised the rental price.
If you want to plant something, but not have to harvest it, you could plant buckwheat. It'll choke out the other weeds and put nitrogen back into the soil. Mow it down, plow or disc it in, and plant something else when it's about done. The mowed stuff will put more nitrogen as well as good organic matter back into the soil.
Joe
   / What should I plant? #16
Instead of booting him, tell hm the rent is 150 pr acre (going rate here in Michigan for row cropping) and see what he says before giving him the heave-ho..... A bird in the hand is better than a sharp stick.....
1581 (A54756)
1581 (A54756)
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 KZ Sportsman...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2014 MACK ELITE...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
