what size 3pt blade?
   / what size 3pt blade? #1
gunnar52
Hello,
Looking at getting a bobcat 3pt blade for a ct 440. Should I get the 7' or 8' blade. I'm new to tractors......
thanks!
Gunnar
   / what size 3pt blade? #3
The 7' would get narrower than your tractor if your working with over 30 degrees of pivot.
I use a Bush Hog 5007 for snow removal with my ct335, which is only about 65" wide. On a 30 degree angle the 7 footer puts the snow just past where my tires tracked. It works well for clearing some of the tight places that I do.
For anything other than snow, I really prefer using my 8' Woods HBL96 behind my 5210. The 5210 runs 73 inches wide, and the 7' blade will never even get close enough to that hitch to even think about hooking up.
thanks for the info.....much appreciated!
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
FRONT END LOADER BUCKET (A53843)
FRONT END LOADER...
KEWANCE 200 9' GRADER BLADE (A54756)
KEWANCE 200 9'...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
2016 Ford SD Dump Truck (A52377)
2016 Ford SD Dump...
