Tractor Sizing What size Kubota? L or Grand L series?
   / What size Kubota? L or Grand L series? #11
I have a Grand L 3240 & my neighbor has a L3400. There is no comparison. The basic GL 3240 is twice the tractor for not that much more money than the L 3400. There is no other deal I know of that will get you so much more for so little money. The GL will do so much more & do it so much easier & so much more comfortably + it will be worth more at selling time or trade in time. Like 4wd in a pick up truck or ac on any vehicle, it will probably return your extra investment at that time so you can use all the extras free.
Independent PTO over Live PTO, 8 speed sycro shuttle shift over 8x4 non syncro shift, much better seat, flat floor, much stronger & smoother lifts at both ends, break away 3 pt. hitch arms over rigid arms, folding ROP, bigger bucket, heavier, more stable, handier controls, much easier to service, & the list goes on & on. I almost bought the L3400 b4 I was offered the GL for about $1700.00 more. I had to go for the deal & I am so glad when I work mine & watch my neighbor work his. The L3400 is a good machine, but no comparison to the GL3240.
   / What size Kubota? L or Grand L series? #12
I made that decision almost a year ago and ended up with an L4240.
I also have about 5.5 acres and needed to do alot of work. I too grew up on a farm and thought about buying used but couldn't find exactly what I wanted or needed and also saw that tractors tend to hold their value well. There are some deals every once in a while, and if you can wait that would be the ticket.... I couldn't.
I'm young and rather than repeating my father and buying numerious used tractors and still not having the right one, I opted for a new tractor.
I'll say that Kubota, JD, NH and Kioti were on my list. I had no Kioti dealer local (just saw a new one this weekend darn..) so that kicked it out and made the other three fairly hard to compare. They are all good machines and dealer availabilty should be priority one. I was lucky to have atleast 2 of each withing 20 miles each way.
Second I determined how "big" of a tractor I needed. I have a few cattle and wanted to move a round bale so that put me into a range but I was also restricted as my property is Lake front and soft for 2 acres that I'm building up. (I could have taken a smaller unit and used ballast but even now I'm glad I didn't go smaller as I still need some weight!) But I'm not too heavy for what I'm doing.
Next I determined PTO HP. This size machine needs a 6' implement to cover the back tires and I've read you need about 5hp per foot for rotary cutting. I now have 35 ptohp and I'd say that 6 per foot would be a minimum, atleast with our thick grass down here.
I was fairly certain I wanted HST as it makes small jobs around the house much easier and quicker. Primarly what i'm doing here. I've gotten several comments lately at how fast I can get a job done, moving and leveling dirt etc.
I then decided to step up the "quality" on all the machines (like a Grand L vs a standard L) because of the time I would be spending on it. I think a standard machine is great for someone who might put 50 hrs a year on a machine but still requires one but is watching $$.
I also compared lifting capabilities of the FEL and 3point. The grand L outdid the other two.
Finally I visited the dealerships again (I probably made 2 dozen trips in a month haha). I test drove them all, my JD dealerships does not keep alot of stock and really hurt their chances as I wanted to drive exactly what I was buying prior to buying but there was no way around that...and I started out wanting green! The NH were just ok, nothing set them apart and again, low stock. The Kubota dealer had atleast twice the stock as the others. And at that time last year prices were soaring. The lot stock was cheaper by as much as 3k as compared to a new tractor ordered that day so the Kubota was cheaper than the other two. That allowed me to end up with a few more HP than I was originally planning for and allowed me to go with the largest FEL.
You won't find anyone on here that bought to much tractor, or is downsizing... but you'll find a few that are upsizing!!!!
The final nail in the coffin was the HST plus of the grand L. I leave my tractor in stall guard and auto throttle advance. I didn't like that the JD required running 2300 rpms the entire time you were on it. I use the dual speed for that extra upmph or speed w/o having to stop and switch a gear. These were the biggest reasons I went with Kubota and 200 hours later I can say they are worth even more than I anticipated!!
Having said all that, for what I wanted/needed, I feel I made the right decision with the Grand L. More tractor for less price, and I even spent the extra for the cab, larger FEL, Dual rear remotes and a front remote. No dust, no sweating, no freezing, no rain, no wasp, and I have tunes!!!! I hope this tractor will last me 30 years!!!
Consider what you'll be doing with it and the implements you'll want to use. My grapple stays on my tractor as much as my bucket. I don't even have to get off to hook up a chain anymore!!! I get 3 times the work done!
   / What size Kubota? L or Grand L series? #13
I'm probably biased....but for getting the most out of your budget, you might also look at what the M series has to offer in terms of frame size and HD application. IMHO the M5040 or higher will out class any of the grand L's in terms of brute force....but I've already stirred the hornet's nest, just an option to look at when shopping. if you want a HST and trinkets, go GL bb
   / What size Kubota? L or Grand L series? #14
I just glanced quickly and I'd say yes.. brute force, if you are looking for a bigger frame tractor than what the Grand L gives you. But being that he was talking about a B series in the beginning and only 5 acres i'd say the M is a bit to big for his intended use.
   / What size Kubota? L or Grand L series? #15
x2 to what LD1 said.
While I agree with the spirit of oldgeezer's post the GL 3240 isn't 2x the tractor the L3400 is but it is a heck of a good deal with a lot of extras for not much more money. Particularly when you add the LA724 loader into the mix.
There isn't much of a difference in loader capacity with the default LA5xx loader.
Without a doubt if I were doing it again I would go with the Grand L over the L3400 but that is NOT because the L3400 isn't able to do what I needed it to do on my 26 acres. I'd say it is perfectly suited for everything. I would enjoy the extras on the Grand L even though I don't need any additional capacities. This is also particularly true with the new Grand L series and the HST+. I love the extra range within the range for loader work as I sometimes operate the loader in L range and would be nice to speed up a bit without having to change the range when I go to dump the bucket.
As far as resale value goes, I personally don't think that you are going to be better off with one vs. the other 10 years from now. Around here in the used market tractors are sized by HP and "does it have a loader". Maybe 1 out of 10 used tractor buyers will appreciate the difference between a GL3130 or a GL3240 and a L3400. Don't get me wrong - the differences are substantial wrt. capacities especially with the LA724 loader - just that I don't think that you will get your money back on the Grand L. Thats not a reason not to go for the Grand L since it gives you so much more for so little extra.
Thank you to everyone for the great responses!
I may be able to get to another Kubota dealer today to see the Grand L.
Thanks for all the helpful responses...I picked up my L4240 yesterday!
   / What size Kubota? L or Grand L series? #18
so where are the pics:D
   / What size Kubota? L or Grand L series? #19
The 40 series is a grand slam (NPI) for kubota. Quiet,capable,comfortable and relible!
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
2011 International WorkStar 7300 Hazardous Material Tanker Truck (A52377)
2011 International...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
