What size snowblower for B7510?
   / What size snowblower for B7510? #12
Blk88,
I guess if using the blade I could push snow going both ways. That way I could make a narrow driveable path first, and than I'd just see-saw back and forth at an angle between the sides, to make it wider. Pushing with the FEL going forward and with the blade in reverse. It's bound to make the process of clearing go faster. On TBN I have read a few older posts that mention using the back blade and I thought I'd ask.
In your neck of the woods there is probably a lot more snow then here. So. Good luck with the blower.
Hey, Texas Dodge,
Snow for us northerners is just an excuse to complain. We go play in it for a while, than go in the house, put another log on the fire and say: After all that hard work I deserve a .... (fill in drink of choice).
   / What size snowblower for B7510? #14
I just picked up a provost lynx 62 for my B7510 - I am hoping it works, because it is sitting in my driveway! :)
   / What size snowblower for B7510? #15
I just bought a 2007 b7510 with FEL and have been hunting around for a snowblower. As an alternative, I may work with a welder friend to "cut down" a bigger (it's 72 in) blower I have. The Kubota manual isn't really clear on what is appropriate. It says a maximum "digging depth" of 60 inches and 400 pounds. I assume they mean a maximum cutting width of 60 inches. Also, the manual says a "subframe" is required for a snowblower...anyone know what this is? Thanks
   / What size snowblower for B7510? #16
The subframe is used for the 'front mount' blower. I assume you are talking about a rear 3pth blower for your B7510. The digging depth is likely referring to a back hoe. The reference to a subframe may also be referring to the back hoe
   / What size snowblower for B7510? #17
Thanks. That makes sense (re: the subframe). There is a separate section for back hoes. Maybe they made a mistake (?) in the manual and meant to have cutting width for snowblowers. I think 60inches may be a reasonable maximum snowblower width for a tractor this size.
   / What size snowblower for B7510? #18
The B7510 is rated at 15-16 hp on the PTO. My older B1700 was rated at 13 PTO HP and had no difficulty running a 54 inch Agro-Trend rear mount snow blower. A 60 inch on a B7510 sounds about right.
   / What size snowblower for B7510? #19
I have a 60" Agrotrend on my Kubota B7800 (22HP at PTO) and it throws the snow far! the B7510 should do just fine.
I just spent 3 hours and 45 minutes blowing 18+" of snow in our driveway and my neighbour's place. I am happy I have a tractor with 15" of ground clearance, 4WD and big chains on all 4 wheels.
   / What size snowblower for B7510? #20
I have a 5' Meteor blower on my B7500. It seems to be a good size for the tractor.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
QUINCY INDUSTRIAL AIR COMPRESSOR (A52706)
QUINCY INDUSTRIAL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
