I replaced the points and condensor, and the engine now (eventually) idles quite well. I'd even say it purrs. It purrs like a 52 year old cat with a bit of rust and a cold, but it's a purr none the less. /forums/images/graemlins/grin.gif
However, I think there were multiple problems at work, because another behaviour is now apparent: after I adjust the speed with the throttle, it oscillates (slows, revs, slows, revs, slows, revs ...) until it eventually converges on a steady state. This only seems to happen under no-load conditions and when the engine is running less then 1200-1000 RPM's or so. I can see the governor rod moving back and forth as this happens.
soundguy: Other then really basic stuff like oil changes and simple maintenance--on an '89 corolla--I have no mechanical experience. So the basic information on the points was appreciated! I wasn't even sure how to accurately turn the engine by hand. I've been learning quite a bit, these last few days.
jinman: One of the first things I did when I got it was to spray some carb cleaner in the carb. The fluid that poured out was significantly thicker then what went in--it looked and flowed more like warm maple syrup then what was spraying out of the can. I'm thinking this is verification that the carb is pretty dirty? Or is that normal?
I've already adjusted the idle and the main screw according to the operators manual and Soundguy's earlier advice. I'll take a look for that drain screw, and clean off the outside and look for anything obvious.
I've now replaced all the easily replaceable ignition stuff (except the coil): plugs, wires, cap, rotor, points, and condensor. All gapped correctly.
But, it certainly does have plenty of power to drive the 6' brush hog, and it doesn't stumble under load ('cept when I run over something I shouldn't have /forums/images/graemlins/blush.gif ). The no-load rev oscillations add character. /forums/images/graemlins/smile.gif
