What to attach to drawbar?
   / What to attach to drawbar? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Just took delivery a week ago of an International 1066.
So far, what I do around here when a tree (for example) might fall is bring out the backhoe, cut the tree and then push/drag it somewhere. Using the front bucket for a drag situation is always......a bit of a drag! Usually have to go in reverse which can create traction issues... If I go forward and pull with bucket, then chain is going all the way under machine and I risk running over it during a curve.... I've dealt with it but don't like it.
Now, with the 1066, I'm realizing we can maybe just use it. So, the tractor has a draw bar hanging out the back. If I wanted to attach a 3/8" chain to drag a stump or something.... what's the best way to attach chain to drawbar?
(side note as I think deeper on this.... this might not happen as easily as I'm thinking because I also bought a hydraulic mower to pull behind tractor and the hydraulic pump will bolt to the back of tractor so it can be "easily" taken off......but it's still going to be a pain in the hiney so it might not come off as easily nor often as I'm imagining)
   / What to attach to drawbar? #2
You need a $20 clevis attached Chain Grab Hook. Readily available at TSC, Rural King, Agri Supply and other ag oriented retailers.
I pull loop-end nylon straps too.
   / What to attach to drawbar? #3
You probably want a clevis D-ring with a pin that is matched to the hole size in the drawbar. Get one with a regular pin (not screw in) that has a cotter pin or lynch pin on the bottom. These types of rings are strong and easy to use -- if you have to remove it to feed or remove a rope/chain, it's quick. Tractor Supply sells a bunch, but I think I got mine online somewhere.
The benefit of a D-ring is that it will work for rope, cable, or chain.
   / What to attach to drawbar? #4
This is what I use on my tractors, about $20 at TSC:
   / What to attach to drawbar? #5
BTW, if you have to skid logs on the ground, the better solution is to use a skid plate or log lifter on the 3-pt hitch, so that you can elevate the front butt end of the log off the ground. Dragging logs with the drawbar is not going to be very efficient, plus if you plan to use it for firewood or lumber, you're going to get the bark dirty and it's harder on chainsaw chains or saw blades.
   / What to attach to drawbar? #6
Another idea is if you get shackle make sure you get one that screws in because I have had a branch or stick pull the hair pin out so you might have a chance of losing the pin. But if you use a screwing from the top less chance of it falling or get knocked out the draw bar.
   / What to attach to drawbar? #7
And if skidding and end of log catches on obstacle it's going to be somewhere between minor and major catastrophic....
Dale
   / What to attach to drawbar? #8
Dale
Very good point -- I am pretty sure we've heard some of those stories here on TBN.
Modern tractors usually have the drawbar below the rear axle, so it would be hard to pop a wheelie and flip over when a drawbar load hangs up, but I've heard all sorts of stories with issues on older tractors, or rigged up pulling setups on newer tractors. It happens!
   / What to attach to drawbar? #9
There have been two discussions of merit if not gone to point of nausea... What drawbar to use and tow/snatch straps/chains..
Won't go into any because if interested each can search them out and read them... My point no matter what you are towing with (drawbar) and what hook up (straps or chains) if log or load chatches on a rock or end digs in and stops moving while tractor is still moving, SOMETHING IS GOING TO HAPPEN....Think the idea of a of well designed skid plate or arched lifting skidder would be prudent... Anything to allow whatever is being drug without hindrance...
Northern Tool #51963 minimally ...Might also consider the # 41255... Search string of "log skidding" will show up other things... Keep In mind I am only suggesting not endorsing...
Dale
Thanks for the ideas. I'm aware of the idea of using a skid plate. I don't burn wood so this won't be for firewood. It usually gets placed in the burn pile. (when we DO cut for my wife's cousins firewood next door, we cut in place and either put into his truck or loader bucket and just dump it at his pile)
I don't want to say "this is strictly" for cleaning up a mess.... but that's the primary thought.
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
Nugier H40-7 APBD H-Frame Shop Press (A59213)
Nugier H40-7 APBD...
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
