John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,489
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
There have been two discussions of merit if not gone to point of nausea... What drawbar to use and tow/snatch straps/chains..
Won't go into any because if interested each can search them out and read them... My point no matter what you are towing with (drawbar) and what hook up (straps or chains) if log or load chatches on a rock or end digs in and stops moving while tractor is still moving, SOMETHING IS GOING TO HAPPEN....Think the idea of a of well designed skid plate or arched lifting skidder would be prudent... Anything to allow whatever is being drug without hindrance...
Northern Tool #51963 minimally ...Might also consider the # 41255... Search string of "log skidding" will show up other things... Keep In mind I am only suggesting not endorsing...
Dale
I've not been impressed with any of the Strongway or TimberTuff log handling equipment I've seen. However, if you are going to be dragging a fair number of logs behind a tractor or ATV/UTV, I do agree that a logging arch can make a lot of sense. You can move a much larger log more easily and with less power, you don't tear up your trails as much, and the logs stay cleaner.
Do keep in mind that if you are hauling something heavy on wheels and in hilly terrain, it's not so much a matter of what you can pull as it is a question of what you can stop.
You can make a logging arch pretty inexpensively, if you are good a scrounging and know how to weld. I'd suggest using something other than the Strongway Arch as a model, as it lacks proper bracing/reinforcement at the joints. The Cadillac of logging arches are made by Logrite, they aren't cheap, but they will last several lifetimes. (They also make the world's best peaveys and cant hooks, if you happen to be in the market for one.)
