Buying Advice what to buy
   / what to buy #101
Here is some of my story with Foton tractors, marketed here in Western Australia as Euroleopard.
I bought a 504 Euroleopard which is a rebranded Foton 50 ehp Roll frame and sunshade 4 unequal WD Very Very happy except paint is not good
Chinese brand engine it ran my NH 570 square baler to the baler's limit in hilly country and NH recommend 80 ehp min.
It runs my JD 348 baler with ease, but then again the JD cannot bale at the same rate as my NH could.
I have run my Bale Bandit with it, that was a bit of a challenge on very steep hills even ballasted and Bale Bandit needs min 90 hp but the bandit has its own pto driven hydraulic power pack as tractor hydraulics do not give 92 litresPer Minute at 2500PSI need to run the bandit.
It pulls a 7ft grader blade in loamy country and I can fill the blade wit soil. Bought the tractor secondhand with 192 hrs on clock f0r under half new price, it now has around 1300hrs
Only problem a new bearing for the shaft driving the front wheels Bearing and two seals (one to keep oil in and outer around other way to keep dirt out) cost $27.00 but I put new oil in transmission $200.00.
One other issue is that the fuel injection pump is not supplied with oil from the engine sump pump. Instead it has its own little sump and the oil therein needs to be changed when engine oil is changed. There is a small drain on the bottom and a small filler at the top.
So happy with the 504, I bought a 604 with 122 hrs for less than half price, equipped with level lift front end loader a perkins 1000 series 4 cyl naturally (non-turbo) made under licence in china.
Fantastic it runs the bale bandit better than the 504 and as fast as i expect the bandit to go.
Handles the 1/2 tonne packs of baled hay with ease and pulls my 2000litre 18 metre boom spray reasonably well a bit slow up steep hills when full but soon learnt to do those paddocks when the spray tank is not so full.
Have had clutch problems. The previous owner was quite aged and apparently traded it due to inability to manage a heavy clutch so unsurprisingly at approx 700 hours clutch plate worn out
Not easy to get a replacement so refaced it
At 780 hrs the clutch failed again, this time friction material stripped off clutch plate on one side
Very close inspection showed pressure plate dished toward centre by approx 1.9 mm
Sooooo machined plate and flywheel resurfaced clutch plate with material giving some 187 thou total thickness and bonded and riveted not just riveted (a belt and braces approach) cost of that total under $500.
Now reassembled and about 350 hrs done with fingers crossed
Could do with more hydraulic capacity ie FEL a bit slow on lifting but again VERY VERY happy
All of this about $40K cheaper than some other well known brands albeit a sunshade rather than a cab.
At the moment considering buying a 404 with loader (secondhand) to use in delivering my hay packs. I have set up my truck to carry 10 packs of hay (210 bales) with a 4.5 tonne trailer behind with ali ramps. The idea is to take my FEL with me and use that to unload the packs. I have developed an allergy to unloading"idiot cubes" of hay by hand. Need to check the lift height of the loader to ensure that the forks will reach the top layer of packs.
No hesitation to buy another if needed, price power and performance TOPS gave best bang for buck.
Was considering an 82 hp model with FEL, but procrastinated too long and it went to another happy home.
I also have a Jung Liang (unsure of spelling) industrial front end loader 10Tonne 125 hp class 1.7cu metre bucket Deutz motor under licence and very happy for my farm use again bought secondhand with 117 hrs
Anything else for the price of that class I was looking at a 15000 hr machine ready for a full rebuild
I am fortunate as have mechanic brother so not overly challenged by the foton dealer closing in WA
So long as you realise that in all probability the level of dealer backup will not be the same as other mainstream tractors no problem, but on the other hand you have every chance of getting a newer serviceable tractor of higher specs for your money
BUT i would suggest that as far as possible do not buy a tractor that barely meets the requirements of the job
Having reserve capacity for the job increases flexibility to take on other tasks if they arise and provides a margin of safety on your present tasks. Some I know have come and asked what size tractor for their lifestyle block so I tell them and almost invariably they buy the bare minimum because a bloke in the pub told them
Now if I am asked I suggest they ask someone in the pub because it is clear that blokes that prop up the bar in the pub are smarter than me who is out and actually doing the job!
It is not as if I do not have experience with tractors, there is at least 10 on the farm at the moment with dozen or so over the years, the current list is :
Fordson E27N full track crawler, Case 930, Case 930 Comfort King, Case 830 Comfort King Western Plains model, Case 4190 Fwa with FEL, Case 2280, Universal Farmliner 445, Euroleopard 504, Euroleopard 604, Allis Chalmers WD, David Brown 780 with forklift, and though technically not a tractor the Jung liana front end loader. A sampling from the past includes several E27N ford sons, petrol/kero and P6 diesel, Chamberlian 3380B, Massey ferguson 175, several Ferguson TE 20, International WD 6, International BTD6 bulldozer, John Deere 2700,..... You get the idea.
Value for money, the Fotons FOR ME (note for me) have proved very hard to beat even though there is no dealer within it seems 2500 km of me.
My buying advice is do your homework, even mainstream dealers do not have a full parts inventory, but usually parts will be available somewhere in Australia, and there are fewer dealerships than there was a few years ago. Further even big mainstream names now supply tractors built in Mexico, Brazil, eastern Europe. India and China. The Tractor world is now globalised.
   / what to buy #102
Coondle - that's a great rundown of your experiences.
Owing a Jinma in NSW Australia, on what is basically a hobby farm, the biggest issue I have had is the hard time my neighbours give me!
The quality is certainly not the same as the bigger names and I'm always having to fix something, but it's been a great introduction into tractor maintenance! Nuts and bolts are always working loose, the electrics are crap, they leak, the odd bits break etc etc. but they keep going.
In a thousand hours, I've done a head gasket, new water pump, new radiator, axle seals, re-wired sections, and replaced gauges. But for what is basically a hobby, the price means I can afford to own a tractor without talking to the bank.
I always tell people not to buy a Chinese tractor unless they are prepared to do a bit of maintenance themselves. Parts are a constant battle but between local guys and Tommy at Affordable in the US, I always get what I need.
I had a wry smile when my neighbour was over last weekend, taking a break from splitting his well known brand tractor, and looked at mine and said that tractor doesn't owe you anything....
   / what to buy #103
Nowhere near the problems experienced by you Catch95. My tractors just keep on keeping on.I
I too ran into the loose nuts/bolts syndrome particularly on the FEL fitted the 604. Digging hard soil I snapped several bolts and broke some of the casting off the bell housing.
I was cleaning and enlarging a dam at the time, a job more suited to a tracked machine.
Took a little effort to drill the high tensile studs out of the frame. A tipped masonry drill bit sharpened much as a standard drill bit would be and plenty of lubrication with slow drill speed did the job, though quite time consuming. Re-tapped the holes and upgraded the bolts from grade 8.8 to grade 12 (grade 12 available in metric.). The mounting on the bell housing was more interesting.
The problem with the bell housing occurred at the same time as the second clutch plate failure. Having split the tractor, I drilled right through the casting into the flywheel area which gave plenty of casting to tap into and fitted longer grade 12 studs. Original penetration of stud tread was around 25 mm and new penetration more like 50 mm.
I had had issues with studs working loose and needing regular retightening. Current installation has remained tight despite similar if not greater usage. Cost apart from my time (which you would realise is VERY valuable!) was 2 drill bits, 2 taps (a standard and a plug tap, I had a plug tap for the front broken stud holes) and the new high tensile studs.
I am intrigued with the strident cries of doom and gloom about Chinese gear. I am old enough to remember (and young enough to be able to still recall) the similar cries resounding in the 50's/60's about Japanese gear and in the 90's about Korean gear but those two countries learnt that quality does count and upgraded. China is on the same improvement trajectory.
I saw a TV doco on wind power. The Australian manufacturer was in a tin shed with grey concrete floor and workers in blue denim style clothing. The Chinese plant was brightly painted, brightly lit and the workers in smart uniforms with hair nets and white cotton gloves, quite a contrast. Incidentally China produces more electricity from wind power than the entire Australian power production.
When it comes to motor cars, tell me what car manufacturer other than 2 from Korea offer a 7 year (YES SEVEN YEAR) unlimited kilometre warranty. We bought wife's car with only a 5 year unlimited km warranty but with 248,000 km on the clock and 1 week before the 5 years was up we had all warranty work attended to and with very good grace on the dealer's par, not "what do you expect from a car that has done almost 1/4 million KM".
No it was "thank you ma'am please sign here to show the repairs were done and is there anything else we can help you with?"
China may not be there yet , it took the Japanese decades to be tops in quality, the Koreans about 15 years and I think the Chinese will be up with the very best in another 5 years. Try the TUNLAND utility with a 2.8 litre Cummins diesel as a power plant, I am considering it as a replacement for my 12 year old Nissan 4X4 tray back which has 350,000 km on it. About $35K for a Japanese equivalent product, $25K for the Foton Tunland. I am pretty sure the $10K difference will stay with me.
   / what to buy #104
I know I live outside of Australia, but thought my comments might be of use.
I have a Jinma 554 tractor (2007) that I bought as a crated unit. I paid $15,000 US for the tractor ($9,800) and FEL ($3,600 US) - the rest of the money was taken up for delivery.
I have a large 40' x 80' workshop so I had somewhere to assemble the tractor at my leisure. I have had just a few problems nothing extensive and for the most part, my fault. The quality of the electrics leave much to be desired, but for the money paid, can't be beat.
I don't put a lot of hours on my tractor - around 70 a year or so. I got what I could afford and it has worked well for me. My only regret is not buying one with a factory cab - can get down to -40 C where I live in the winter. Even at -15C blowing snow, it gets very cold and uncomfortable. My driveway is around 600 yds long and when there is 18" of snow to blow, it gets uncomfortable for me:thumbdown:
I have since done a fair bit of research into Chinese tractors and two brands I would buy if I needed another would be either Dong Feng or Foton. As with any imported Chinese tractor, there is the need to be mechanically inclined.
I have been happy with my purchase - a major brand one would have cost four times that price approximately, to do the same work.
Each to his own, but don't think Chinese tractors are not up to the mark - they can be very good buys IMHO.
Cheers.
   / what to buy #105
A news article on agrison. May not be up to date but I came across it today and thought it worth posting:
Agrison in hot seat on tractor imports | Farming & Machines News | Weekly Times Now
"Now, government watchdog Consumer Affairs Victoria is investigating the business that imports tractors and rebadges them Agrison.
Many customers have taken legal action against the dealer alleging issues such as substandard machinery, a failure to provide manuals and invoices, a lack of spare parts, poor repairs, frequent breakdowns and poor warranty service.
Justice Department figures show businesses owned by members of the Yokus family - trading as Agrison, Agricat and Agratrac - have been a party to more than 20 cases in the Victorian Civil and Administrative Tribunal in four years."
   / what to buy #106
All this and more is true.........How do I know...........I am one of the people cited in this article.......been there and done that.
   / what to buy #107
   / what to buy #108
Cheers.
I agree with this.
if i could only keep one of my two tractors it would most likely be My Chinese built Rhino... Nothing wrong with the Ford but my Chinese (Shanghai) is my Go To tractor most of the time.
   / what to buy #109
Recon I may have found a better opion wrt parts for the Agicat/Agrisun.
All the usual disclaimers
Circle D imports Perth. Got my air filters from there. Right part the first time, prompt and sensibe pricing/freight
   / what to buy #110
From memory Circle D is also known as Luzhong Australia. The only official Luzhong dealer with factory support.
2003 Big Tex 10PI...
1827 (A51248)
1827 (A51248)
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2018 KENWORTH T270 SERVICE TRUCK (A57192)
2018 KENWORTH T270...
