What to buy
   / What to buy #11
My lawn tractor does a great job in the snow. It will go through 12 inches of snow as fast as I can drive. It is usualy 3 passes to remove the snow and 2 or 3 to clean up the dribble
   / What to buy #12
just another data point:
I mow and plow with a JD425 AWS garden tractor - gas, 2 WD with locking diff. For snow plowing, she is equipped with a 54" blade, hydraulic angle and lift, a couple of little suitcase weights and tire chains. I've plowed snow deeper than the blade is tall with no problems. The all-wheel-steer makes her extremely agile and she will plow circles around much bigger machines in confined spaces. Being a good neighbor, I plow all my neighbors drives plus mine (7 drives about 500 feet total) in about an hour, and this is being very careful around their garages and cars. 450 feet of open drive would take considerably less time to do.
Also, for mowing around trees, gardens, bushes, etc. the AWS can't be beat. I mow 2 acres in 1.5 hours with ease. I have a lot of trees and gardnes, but only have to trim with a weedeater about once a month. Coupled with hydrostatic drive, the AWS takes care of most of that.
So, I'd say you don't need 4WD. But, do get a heavy machine. Weight to the ground is paramount for plowing. 20 will be plenty. AWS (or similar systems) should also be given serious thought too. If you even think you'd like to have a loader or 3pt implements, make sure you get a machine that will support that. Don't buy too small and regret it. But, don't buy more than you'll ever use either.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
