jcmseven said:Tom,
I suppose it is possible the fuel might not have been USLD which might have fooled the sensor (I have heard this can happen), but I am impressed by the fact my truck never ran badly. In fact, had the light not come on I would have never known. The truck--through all of this--has run perfectly. Since my original posting the light has not come on again. I am cautiously optimistic it will stay off. I have opted to not change filter unless the light comes back on and stays. I ran the culprit tank of fuel low and just filled up with a new tank. Hopefully, this will prevent any issues. I did not sample the fuel from the last tank, but will do so if the light comes on again. As I noted I used the separation treatment recommended by Ford, so hopefully that helped some. I will keep posted, and I appreciate the helpful comments so far.
John M
A filter change would not be required--what the light is telling you to do (in this case, maybe erroneously) is to drain the fuel water separator. It's doing its job, if there really is enough water accumulated to activate the sensor. The 'separation treatment recommended by Ford'--was that the demulsifier additive? If so, that will cause the water separator to fill more rapidly, as it will cause water to be more easily extractable from the fuel.
Running the tank to nearly empty won't particularly help because water will be at the lowest point of the tank--the part you didn't burn. If you really did get a big shot of water (doubtful) you would need to drain the tank itself, via its drain plug.
