What to look for in an old second hand tractor
   / What to look for in an old second hand tractor #11
You might be interested in this site ... sometimes it has what you may be looking for about a certain model year tractor.
http://www.tractordata.com/
Leo
thanks for your help leo some good sites
cheers mith
   / What to look for in an old second hand tractor #14
Look for the 'usual' stuff.
Oil in water, water in oil, leaks under tractor, or evidence ov leaks in the paint. Look for evidence of repair.. Good repairs are ok. Bad or questionable repairs are a warning sign... for instance.. RTV extruded out around a casting mating surface may mean a proper gasket wasn't used.. etc.
Check whgeel hubs for play by rocking the tractor side to side. Look for play inthe steering members and linkages/steering box. Look at the wear or scuff patterns on the tires.
Drive tractor in all ranges and all speeds. Run it long enough to see it's hot idle oil pressure. Start it when it is could to see how easy it is to start. Verify that it charges, and that instruments work. Check clutch pedal travle, and even the wear on the clutch pedal itself. Check the brakes. Check the lift.. make sure it is strong. Try to test it with an implement on it, lift it, and then turn the tractor off and see how long the lift stays up. If possible also try out a PTO implement with it.
If a private seller.. look at other things he owns as a 'guide' to see how well he maintains things.
Good luck.
Soundguy
thanks for all you help - i have a friend who is going to give me details of a tractor being sold by one of his customers. he says he knows the tractors history and that it is good
so hopefully it will work out
thanks for all your help now i feel better prepared to judge a tractor
thanks /forums/images/graemlins/grin.gif mith
   / What to look for in an old second hand tractor #16
   / What to look for in an old second hand tractor #17
by old i mean early 1990's
awe.. that's still smelling new !
most suff before that is totally trashed or is to be found at the scrap yard
not hardly.. lotsa older machines earning a days keep out there..
-what kind of hours is old but realistically is going to be in good condition? 1000hours? below? more?
1000 hours is just getting broke in good..
look for the usualy problem.. leaks.. repairs.. etc.. drive the amchine in all gears and ranges cold and hot and see how it starts cold and hot.. do the hyds work.. does it charge.. will it pull ( clutch).. does the pto work under load and does the 3pt hold a good load....
soundguy
   / What to look for in an old second hand tractor #18
Check the date of the original post. Reactivation of old thread (not necessarily a bad subject, though).
Roy
AUCTION STARTS HERE @ 9AM (A52706)
AUCTION STARTS...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
43030 (A51691)
43030 (A51691)
