what to order for mounting a 47" snowblower from a 445 to a 2320-
   / what to order for mounting a 47" snowblower from a 445 to a 2320- #11
I bought a used 59" blower and mounted it to my 4110. I used the drive shaft, fabed a mounting plate for the frame. Bought a stub shaft, two bearings, and added a support for the lift cylinder. Bearings were twenty dollars, shaft twelve dollars, and some scrap plate steel off the rack. Works like a charm and clears a huge path.
Good way to go imo, I compare things like this often. Some are too complex to make but very often I can make it my self for less than 1/3 of what the manufactures charge.
   / what to order for mounting a 47" snowblower from a 445 to a 2320- #12
I have some extra drive shafts from a 59" snow blower off a 955. I am sure they would fit other models as well. I have a long driveshaft, the intermediate one that bolts to frame(three bolts) and the short one to the blower itself. $500 for all three. Also would sell individually. Located in NY near Saratoga Springs. 744-3278 in area code 518.
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
23" X 27" ROLLING METAL CART (A58374)
23" X 27" ROLLING...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
202483 (A54757)
202483 (A54757)
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
