What to use to seal hole in concrete wall
   / What to use to seal hole in concrete wall #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
At my Mother's house she has leak in the basement. I went and looked. It's where the water line comes thru the poured concrete wall. It looks like a motar of some type had been used and has cracked and fell out. About 3/4" gap around the pipe. Dirt and water has come in from the recent rains. First time it has leaked since the hose was built 15 years ago. Any suggestions of the best way to fix? I am hoping there is something that comes in a caulk tube that will make it an easy fix.
   / What to use to seal hole in concrete wall #3
I think James's suggestion is a good one for the average concrete sealing problem, but anytime you seal around a water pipe with rigid material, either the material will fail or the pipe will be damaged. The problem is that the concrete and the pipe do not expand at the same rate with heating/cooling cycles. I think you need something around the pipe that will have a pressure seal, but be both flexible and waterproof. The real problem is the drainage on the outside of the wall is not sufficient, so this will be a recurring problem area in my opinion. I believe you need some soft material around that pipe that can be packed in enough to stop flow, but still flex slightly. Now, I could be terribly wrong, but every time I see a pipe come through a concrete foundation or wall in Texas, they always have a foam expansion boot around the pipe. These are not really expected to be water tight.
   / What to use to seal hole in concrete wall #4
I wonder if there is a flexible, closed-cell, spray-on expanding-foam product that would work for this use? I think regular spray foam insulation/sealant probably gets too rigid/brittle when it sets up. I have a similar problem in my house with two wall penetrations (one pipe in from the well and one out to the barn) both of which allow water to leak in in very early spring, when the ground is super-saturated (and the ground is frozen everywhere but right against the house!), or after a very heavy rainfall in summer.
BOB
   / What to use to seal hole in concrete wall #5
I just changed out the water line coming into my basement. The penetration was sealed with clear silicone caulk, so I resealed it using the same stuff. Never had any issues before and don't expect any now. As was pointed out, the sealant needs to be flexible to handle movement and vibration.
   / What to use to seal hole in concrete wall #6
I hadn't though about the different expansion and contractions around the pipe,, I have use hydraulic cement to seal cracks. and it works well, but agreed this is different..
James K0UA
   / What to use to seal hole in concrete wall #7
use a closed cell spray foam. i normally use "great stuff" in red can.
as someone else mention do not use hydrualic cement, you could cause the pipe to break.
dig the area out and clean it up. spray foam it. let the spray foam expand and cure (any were form 24 hours to a full week, pending on what you get) then go back with a steak knife (from kitchen) to get big globs off, and clean it up with a razor blade. and then paint it, suggest waiting a week before painting to allow spray foam to fully cure.
an another alternative would be.... Koiphen.com and search for "pipe boot" it will give details of how to cut a hole in a liner such as roofing liner or pond liner. and make a water tight seal. though for you , would need to make another step of making water tight seal between liner and wall of house. if you had some concrete anchors, masonary bit, and some wood you might be able to clamp the liner between wall and wood. to get water tight seal there.
   / What to use to seal hole in concrete wall #8
Thought I should point out that you are going to have to seal it from the outside to do it right, no matter what material you use. Rereading your original post, it's not clear if you were looking for something to seal it from the inside only, or were planning to dig down to the exterior penetration point. I'm afraid that's part of the job.
One thing about using foam, some foams shrink as much as 5% over time. I don't know about spray foams, though. Shrinkage is definitely something you should consider when selecting the material. Also, a lot of materials aren't rated for below grade use. That's something else to check.
   / What to use to seal hole in concrete wall #9
I have used products from radonseal. They worked great fixing cracks in my foundation wall. No more leaks. They sell a product to stop leaks from thru wall pipes in foundations. I don't know if I can post the link, but go to radonseal "dot" com
   / What to use to seal hole in concrete wall #10
I keep seeing this stuff on TV. I can't remember the name. "It's rubber in a can" It's the one where they take a screen door and replace the bottom of a boat with it after spraying this stuff on it......don't know.
Lots of good suggestions already here.
   / What to use to seal hole in concrete wall #12
The hydraulic cement would work and the pipe may experince slight compression but will not be damaged. Like previously said...work fast, you will have a minute before it is hard. If you want to overkill and can hollow out a little soil behind the wall, shove some dry bentonite around the area outside the basement then seal with concrete.
   / What to use to seal hole in concrete wall #13
Precast building sections are joined with bolts...the sealant is for sealing the joints against water.
   / What to use to seal hole in concrete wall #14
If you investigate the hole your mom's water pipe is coming through a little more you will probably find that when the wall was poured a piece of rigid plastic pipe was put there to form the hole. Hydraulic cement will not give you a seal and could damage the water line pipe.
I have a number of these in my basement for well water coming in and water and electric going to a couple barns. Clear silicone works well if you clean out the old stuff first and put it in in layers. 6" of silicone all at once will not set up well.
As was said before, the real fix is on the outside of the wall but you might get lucky by trying from the inside first.
   / What to use to seal hole in concrete wall #16
There is a product and procedure done for manholes and concrete structures placed below the water table. They drill a small hole, insert a tube, and inject a bentonite type slurry around the area that is leaking. It will seal everything up unless it drys up and later re-wetted. Any concrete manhole manufacture would have names of companies that do this and with a little ingenuity, could be done by a homeowner with a concrete drill.
More info coming soon! (A56858)
More info coming...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
