4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,918
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
You can certainly buy an older full size backhoe for that $15K price. It will be 2WD and manual shift. It may or may not have a cab. Expect it will be well worn, but the one you want is one that has not been abused. They are out there for that price. I've seen several that I thought were good buys go in that range this year alone.
It will probably need some work....but shouldn't need anything major, and for $15K it should be able to go to work tomorrow. I would look specifically for JD310 or perhaps an older Case. Both have good parts availability and decent support groups.
I am assuming that you have tools and are a competent mechanic. If not now, you will be - and nothing wrong with that.
As for trailering, I wouldn't. If you stick with rural jobs within a ten mile radius you can simply drive it between jobs. Lots of people do.
A full size JD310 will dig to 14 feet and if it has the extendahoe dipperstick it will go 18 feet. Most have accessory hydraulics instead of using a PTO to run things like a post hole digger. But they do NOT have a 3pt hitch or PTO.
rScotty
I wouldn’t touch a manual shift backhoe. But I’ve seen some pretty decent 90s era shuttle trans backhoes for 15k. But buying a nicer backhoe is a better investment. I had 30k in my last Deere backhoe and it worked flawlessly the entire time I had it I and sold it for a profit. A junker backhoe is going to be an oil leaking, constant mechanic project and a lot more likely to stick you with a catastrophic repair.
