What tractor would you recommend?
   / What tractor would you recommend? #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I am in the market for a used diesel 1965-present tractor on a relatively light chassis. In the size range of a large compact or a small utility tractor. Around the 3000#-3700# range. With between 35-45HP. Would like it to be able to handle a loader/box blade/6ft brushhog/and 6ft 3pt finish mower. It will need to have a live or independent PTO and I would prefer not to have to use an extenal pump for the loader. Would like to be able to run the 3pt and loader at the same time. I can only spend about $9,000 for the tractor. What models would you recommend that would fit this description and be a machine that would last.
Thanks for the input,
Brandon
   / What tractor would you recommend? #2
Brandon - Are you interested only in buying a JD? If not, your question would better be asked in the non-brand-specific buying forum up top, in which case one of the moderators will move it for you. Just checking...
UNUSED FUTURE EXCAVATOR RIPPER (A51244)
UNUSED FUTURE...
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
Navigator 4000 4,000lbs Forklift (TRUCK MOUNT) (A52128)
Navigator 4000...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
RIGID TOOLBOX (A52472)
