What tractor would you recommend?
   / What tractor would you recommend? #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I am in the market for a used diesel 1965-present tractor on a relatively light chassis. In the size range of a large compact or a small utility tractor. Around the 3000#-3700# range. With between 35-45HP. Would like it to be able to handle a loader/box blade/6ft brushhog/and 6ft 3pt finish mower. It will need to have a live or independent PTO and I would prefer not to have to use an extenal pump for the loader. Would like to be able to run the 3pt and loader at the same time. I can only spend about $9,000 for the tractor. What models would you recommend that would fit this description and be a machine that would last.
Thanks for the input,
Brandon
   / What tractor would you recommend? #2
Brandon - Are you interested only in buying a JD? If not, your question would better be asked in the non-brand-specific buying forum up top, in which case one of the moderators will move it for you. Just checking...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52128)
2007 Freightliner...
2016 Chevrolet Cruze Sedan (A50324)
2016 Chevrolet...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
2018 CATERPILLAR 239D SKID STEER (A51242)
2018 CATERPILLAR...
