What tractors are in the same class?
   / What tractors are in the same class? #31
You need to specify engines. The hp/torque curve for my old Kubota 19hp "B" series, and my old 1941 Farmall-A were essentially the same.
However, the old Farmall engine had twice the cubic inches, and used more fuel.
The Farmall and the Kubota could eat a 20-25hp lawn tractor engine for lunch...
Reminds me of the late 50's, early 60's LaFrance fire engines. Some had monster gas engines, and got 2 mpg.
BethesdaEC said:
There is no comparing gas power to diesel power. Gas engines seem to bog down very quickly and lose power under load where as diesel maintain said power. Personally I believe that when comparing the two you should probably cut the rated power of the gas by a factor of two to level the playing field.
   / What tractors are in the same class? #32
I'd say that HP is as good a starting parameter as any i.e. you have to start somewhere to compare...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
