what type of 110V welder to get ac/dc/mig/tig
   / what type of 110V welder to get ac/dc/mig/tig #51
this topic is debated at least once a month on here and usually ends up with the same opinions being voiced - some by people with valid credentials, and others are just flat out preferences or opinions or mere rehashes of promotional literature. certainly, you aren't going to get full penetration in anything with thick - generally, most people are content to agree that around 1/4" is often obtainable with a good quality 120v welder.
the thing that many people still can't get past is that not everything needs full penetration welds. i have seen 1000's of tons of steel up to and over 1" with 5/16" fillet welds. full penetration is something that is generally avoided unless necessary in building construction. on a smaller scale, look at any farm equipment you have. lots of it is made with intermittent welds, and very little of it would be considered full penetration.
also, make sure to understand the difference between mig and wire feed. many people seem to think that if the welding wire is on a spool, then it is a mig. it is only mig if it uses a gas for shielding. every week i see people on craigslist trying to sell a "mig" welder that only works with flux cored wire - that's not a mig. unless it has (or can be retrofitted with) a gas solenoid for shielding, then it's not a mig welder.
every welder and process has its place. i've used a 120v wire feeder with flux core to weld 1/2" plates to farm machinery for a 3ph attachment, and even after lots of thrashing, everything is still working perfectly and hasn't fallen apart. it is certainly more at home welding 1/8" to 1/4" steel, but you can do limited work on much thicker steel as long as you have the heat to get penetration. large wire feeders with flux core wire are used in construction all the time. multiple inch thick steel is welded with them every day. flux core can be used outdoors, along with stick, while mig is susceptible to gas problems due to wind.
as far as what to get, i personally find the 120v wire feeders with mig capability to be the most versatile welder that a novice can get. you can do very thin up to reasonably thick. it all depends on what you need, if you own a skidder or an excavator, then you're probably barking up the wrong tree, but if you own a compact or smaller tractor, and work with small vehicles (light duty truck and smaller) then the bulk of your work should be within the envelope of a 120v wire feeder.
Wow...Thank you. This is the reasonable, level-headed response I was looking for.
I've been searching on this computer for over two hours. I guess I should've come to the tractor forums first, eh?...lol
I haven't welded in over 30 years, since high school. But I need to get back into it.
Thanks again
   / what type of 110V welder to get ac/dc/mig/tig #52
What is everyone's opinion (as far as 120v goes) on the big box stores' Lincoln Electric (Pro Mig/Weld Pak) 140 Mig Welder?
They have excellent reviews, and seems reasonably priced at $524.
Or should I be looking elsewhere?
   / what type of 110V welder to get ac/dc/mig/tig #53
Max, from what I have seen, people like them. However, its plastic wire feed system (at least the last one I saw) was the only thing I saw that I would have concern about. The ones in my local store say "hecho en Mexico". I typically like the way Lincolns weld in general. They're very smooth and no nonsense.
   / what type of 110V welder to get ac/dc/mig/tig #54
I have owned a 120v mig 90 amp max I think it was and the only thing it really worked well for me anyway is body work sheet metal.
I would never attempt to repair anything bigger than 3/16 with the one I had the duty cycle was so low you wont get much welding it will be more off than on and while 90 amps is supposed to be good for 1/4-5/16 you wont get much done. jmho.
I have a 250 amp 220v mig now that will weld thin body work sheet metal all the way up to some decent thicker projects and the duty cycle is continuous on most settings except 250 I can stay after it as long as my back and knees hold out.
edit: a small ac/dc 220v 225 amp stick welder is imho probably the best tool for occasional repairs around a farm if I had to pick one welder to do it all for the money that's it.
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2012 PETERBILT 337 CHEMICAL TREATER TRUCK (A55745)
2012 PETERBILT 337...
1ST PRODUCT HYD MINI SEEDER / AERAVATOR (A52706)
1ST PRODUCT HYD...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
