What type of oil/fluid to use for TC30
   / What type of oil/fluid to use for TC30 #1
crossetta
tc30
Hello, I am new to the forum. I punctured a hole in my filter underneath the seat. I believe it is my hydraulic filter as fluid was pouring out for 5 minutes. I wanted to make sure that is in fact the hydraulic filter part 87300043.
In addition, what kind of fluid should I be putting back in and where do I put it back in. Under the hood has a valve that says diesel oil 10w30 for summer but I'm not sure that is the correct place and type of oil to use.
Any advice is welcomed.
Thanks,
CR
   / What type of oil/fluid to use for TC30 #2
If you have an Operator's Manual, the answer will be in that manual.
If you do not have a manual, the New Holland forum is probably a better to ask this specific question.
   / What type of oil/fluid to use for TC30 #3
If the HST pulls from the rear axle reservoir then it uses M2C-134-? (likely D)
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2019 TURNKEY DATA VAN (A55745)
2019 TURNKEY DATA...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2017 Ford Transit Connect XL Cargo Van (A55852)
2017 Ford Transit...
