What weight engine oil do you use?
   / What weight engine oil do you use?
Deere and Kawasaki both recommend 10W30.
   / What weight engine oil do you use? #12
I have been running Mobil 1 Extended Performance 10W30 engine oil for quite some time, and have never had a problem. I'm thinking about switching to 5W30, which is also what I run in my pickup. I'm curious to know what the general consensus is about engine oil weight. Thanks in advance.
I have an Ariens 17.5 HP (single cylinder B&S 31000-series engine) rider that I use as a yard utility vehicle. It gets used year 'round for getting the mail and various other tasks. That means lots of short trips on anything from 100-degree summer days to 5-degree winter mornings. It occasionally gets a couple hour run time if I'm doing something like picking up sticks or spraying for bugs. I used to use 10W-30 dino oil but noticed it seem to accumulate a lot of moisture due to the short run times and it was a bit sluggish turning over in winter. So two years ago I switched to Mobil-1 5W-30 full synthetic and have had no problems. I have no measurable oil consumption during hot summer days, it cranks much easier in winter and for some reason I seem to get less condensation in the oil.
   / What weight engine oil do you use? #13
It depends on your ambient operating temperatures. For the Kawasaki FS730V used in the X500 the OEM Kawasaki owner's manual has this oil chart:
The John Deere owner's manual for the X500 has the following oil chart:
   / What weight engine oil do you use? #14
I use EXACTLY what Kubota recommends in my 2009 Op Manual. 15W-40 year round. I initially used Kubota branded oil but have now switched to Shell Rotella. I can get Rotella at the local NAPA store.
   / What weight engine oil do you use? #15
All my diesels get either Rotella or Delo old school 15w40. Both are fine oils and I go with which ever is lower in price at the Wally. The motor internals will outlast me. And be in fine shape for the next owner or two. I own or have owned equipment with 5K to 8K hours on them that have had regular oil inserted in them for their lifetime, and they still run fine without any noticeable engine wear. I do use syn oil in my Zero turn and generator.
2006 IC PB30500 School Bus (A50323)
2006 IC PB30500...
2022 DYNAPAC CA3500D SMOOTH DRUM ROLLER (A51242)
2022 DYNAPAC...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
Ford 8N Tractor w/3pt. Buck Saw (AS IS) (A50774)
Ford 8N Tractor...
2013 Ford Explorer XLT SUV (A50324)
2013 Ford Explorer...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
