What would you tell a moron . . .
   / What would you tell a moron . . .
Yup, that's the best advice. I adjusted mine yesterday so that when I set them it won't move . . .at all. I figure that's the only way that I can keep myself from screwing up again.
Have a good one,
Dave
   / What would you tell a moron . . . #22
</font><font color="blue" class="small">( Yup, that's the best advice. I adjusted mine yesterday so that when I set them it won't move . . .at all. I figure that's the only way that I can keep myself from screwing up again.)</font> Just one note of caution when doing this: Make sure you don't tighten so much that you are inadvertently causing the brakes to be in contact when not engaged. Read the brake specs for play in your owner's manual and adjust to their specs as it's easy to go too far and wear out the brakes when not engaged. John
   / What would you tell a moron . . . #23
Hi Jim,
I have them adjusted to the factory specs. My problem is that I have ligament damage in both of my knees and I just don't push hard enough on the pedal to actually lock the brakes. I just seem to get them tight enough so that the tractor won't move on it's own. It's my fault, not the tractors. /forums/images/graemlins/blush.gif
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2018 RoGator 1100C (A53473)
2018 RoGator 1100C...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
