what year and model tractor do i have,
   / what year and model tractor do i have, #11
he's given us virtually no info to go on.
if the ring gear wore out.. I';d expect pinion to have worn out too.. but ring gear may hav ebroke.. and pinion fine.
while in an auto i'd replace as a matched set.. in a tractor.. if one or the other ;looked good,, i wouldn't beat myself up about piecing it.
still.. we need more info...
soundguy
   / what year and model tractor do i have, #12
All US-built Fords prior to 1965 use the same starter ring gear, part number 9N6384. Based on the numbers you provided, if the fuel tank sits EXACTLY over the top of a 4 cylinder OHV engine, that's what you need. If it is a three cylinder engine, that ring gear won't work, and there are different ring gears for gas and diesel engines.
I'll ask again, which side of the engine is the starter on?
My bad; the OP wrote ring gear & spider gears, I READ starter ring gear. MUCH more info needed to help him out.
RING 3 STARTS HERE @ 9:30 AM (A51248)
RING 3 STARTS HERE...
2006 CATERPILLAR 345CL EXCAVATOR (A51246)
2006 CATERPILLAR...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2011 CATERPILLAR 140M2 MOTORGRADER (A51246)
2011 CATERPILLAR...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
