What's a good choice when buying a Multimeter?
Status
Not open for further replies.
   / What's a good choice when buying a Multimeter? #51
i get what you meant.....i try to keep one of my meters just for "geek" work because the one i keep in my garage gets a bit dirty.....the other one is in the basement for household electronics, cleaner work, etc....
Geek work > bench or electronics type work. No disrespect intended.
   / What's a good choice when buying a Multimeter? #52
didn't read all the posts so if this has been mentioned....I like an analog meter for checking wiring --- when you're looking for something that happens ie: only when the motor is running ....shaking the wiring to simulate vibration etc....an analog will respond to a loose connection faster than a digital. I had a simpson that I loved -- and lost in a flood. I also have a digital - but miss my Simpson.
   / What's a good choice when buying a Multimeter? #53
If you trust the UL label on a cheap China meter then I got some Milk and Dog food to sell you.
Your argument is a strawman... you can always check the validity of a UL tag registration.
In any case, The only china meter i have ever seen / used did NOT have a UL tag on it... it was a 3.99$ special I grabbed to use once for a side of the road trailer wiring repair in a rainstorm.. after that it got tossed into the tool box...
the OP doesn't want to spend alot of money... to check a 12v batter and a wall socket he needs a 25$ autoranger.. not 100+ plus industrial or precision meter. You can also get cheap analogs from radioshack ( WITH UL TAG ) for 9-14$.. probably work fine.. but the analog model has limited ohms scale...
I'd personally steer clear of the chinese 3.99$ specials for anything other than a use and throw away option..
Soundguy
   / What's a good choice when buying a Multimeter? #54
Yep.. at least 80% of the responders completely missed that point in the original message...
soundguy
I guess most of you recommending Flukes missed this part of the original post:
There are many models to choose from, but I don't want to spend more money than I have to.
There is absolutley no need for a casual user to purchase a Fluke meter. For the average person occasionally chasing 12 volts on a car or tractor or measuring AC line voltage, it is a waste of money.
   / What's a good choice when buying a Multimeter? #55
Whatever brand you choose, try to get one that can use the Fluke style test leads. These are readily available for lots of tasks, including amp clamp and temperature probe.
   / What's a good choice when buying a Multimeter? #56
I understood the point immediately but that doesn't limit my response. I imagine there are some bargains out there on used stuff so why not consider a high end tool at bargain prices if you find them? :confused:
   / What's a good choice when buying a Multimeter? #57
I picked up a used Fluke on the worlds longest yard sale for $50. It works great. I also use an old analog Tripplite(?) at times.
   / What's a good choice when buying a Multimeter? #58
There are definitely bargains out there that can be found. A quick look on ebay found several quality meters art well under $100. $100 isnt really alot of money. Why buy a potentially hazardous cheap meter for nearly the same price? Dont make sense to me.
And soundguy, the fact that Chinese quality control isnt worth a snit, "UL" label or not is very valid in this argument. If you want to essentially trust your life to a crappy chinese meter then so be it. I wont. This is my last post on the subject.
   / What's a good choice when buying a Multimeter? #59
I'm glad it's your last post on this subject.. you keep ignoring printed text in my messages.... so far i havn't reccomended using a chinese meter! I'm saying hit a middle of the road unit and look for a ul tag.
And your fuzzy math skills? potentially hazardous cheap meter at 100$ ?
100$ gets you into a decent quality new consumer grade meter...
An idiot and a garden rake are a potentially hazardous combination... a decent run of the mill consumer grade meter with a ul tag and good leads is on the reasonable side of safety.. at least as far as you can get knowing thet you will be around electricity. ( risk is probably up there with someone taking a decongestant and getting that temporary high heart rate and slightly increased cardiac event risk... ! )
soundguy
   / What's a good choice when buying a Multimeter? #60
I know a lot of guys that have been hurt because they or someone they were working with made stupid mistakes, but I don't think I can recall anyone I ever worked with being hurt by any kind of defective or failed test equipment, UL rated or not.
You run more of a risk by turning on a cheesy Chinese table lamp than you do by using one of their multimeters.
Status
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
