Oil & Fuel whats the best way to fix a crack in a fuel tank?
   / whats the best way to fix a crack in a fuel tank? #11
Another vote for JB Weld. I'd say give that a shot and then come back for more sophisticated advise if it doesn't work.
   / whats the best way to fix a crack in a fuel tank? #12
I tried an epoxy on a cracked plastic Shindaiwa tank, didn't work. I finally took a soldering iron, tank empty of course, and melted it back together, fixed it.
   / whats the best way to fix a crack in a fuel tank? #13
You can just weld that old tank, the metal is double the thickness of automobile bodywork so you can weld without burning holes.
Why did it crack, are the tank mounting rubbers sagged so it bounced on the steering housing ?
   / whats the best way to fix a crack in a fuel tank? #14
Yet another vote for JB Weld. Clean the surface thoroughly first for good adhesion.
   / whats the best way to fix a crack in a fuel tank? #15
I fixed two plastic GAS tanks with my soldering iron. Perform a search online and there are several photos of how to which will help you.
   / whats the best way to fix a crack in a fuel tank? #16
I have repaired more than a few plastic tanks with polyurathane caulking. Clean with thinner and glob the caulking generously to cover the damage or cracked area. Also a good idea to stop drill a crack at both ends.
One brand is FLEXTRA and if you can't find that brand windshield adhesive (sold in tubes) would do the same work.
On a steel tank steam it thoroughly, blow lots of air thru it to remove any vapors and braise the split or hole.
Acid core solder and a hot soldering iron can also fix a steel tank.
For a pin hole type of leak you could use leather or plastic washer with a self tapping metal screw.
Most plastic tanks are PVC and epoxies just will not adhere no matter how rough you sand the surface.
Hot soldering iron and blending the PVC and or adding PVC (aka hot glue gun sticks) also works.
   / whats the best way to fix a crack in a fuel tank? #17
I found a old plastic tank from a small engine. I cut strips and used them as welding rod and welded the leak shut.
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
