boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,789
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
if you look at some "ATV" equipment you can find "pull behinds" graders, box blades, etc... that just hook up behind a ATV / 4 wheeler. or perhaps behind a vehicle. and you just drive down the paths. granted they are more costlier vs if you had a tractor that had a 3pt hitch. but most of them pull behinds for ATV's have some 2 wheels. with a lever you raise up and down. to get depth you want.
granted folks talking about I or H beams. can work pretty good. call around to some local scrap yards, and you should be able to find something. or perhaps put a "WANTED" ad on craigslist.org
box blades, rear blades, grader blades, etc....
if you go with a pull behind box blade, you might want to pay a tad more for "scafricers" they are metal teeth that you can move up and down in front of the box, that helps break up dirt and like. so it is easier to scrap dirt around, and level things out and move the dirt were it needs to go.
Used Tractors For Sale at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, tractors for sale, Case IH, New Holland, Agco, Kubota would be a way to see a lot of pictures of different equipment. they might list a few "pull behinds" or "pull" equipment that might be small enough for your tractor. *shrugs*
with others, you will most likely want chains on rear tires. to maintain traction.
