What's the secret to drilling through 1/4" angle iron?
   / What's the secret to drilling through 1/4" angle iron? #91
I was surprised at 75 responses to a question about drilling holes. I expected some derogatory remarks at the OP and was glad to see only help.
Yeah. If hed just gone ahead and used a 1/4" angle drill there wouldve been no thread. ;)
   / What's the secret to drilling through 1/4" angle iron? #92
The head is solid as a big rock. It is just the table that moves a little.
Yep. Head and all its movements are solid. Movement is in the table.
I am not saying there is more movement than a drill press. Cause I use a drill press where the movement is in the vise as I don't clamp it solid to the table. I would just prefer not to see all that movement wearing things out on an expensive mill.
There is a reason that bridgport et al only rate them for 3/4" drill bits if manual fed and only 3/8 if using quill feed.
A cheaper and similar HP drill press will be rated for larger holes.
   / What's the secret to drilling through 1/4" angle iron? #93
You could always do the same thing with a vice on a mill.
   / What's the secret to drilling through 1/4" angle iron? #94
If it was dedicated for drilling only... Sure. But having to unbolt the vise, then bolt it back on and make sure its square to mill is a pita.
   / What's the secret to drilling through 1/4" angle iron? #96
It is actually not. I can put the vice on in less than 2 minutes. The bed is long enough I can usually just loosen the the bolts which takes about 30 seconds and slide the vice to the end. I am clearly not a real machinist, and I commonly use the vice to hold what I am machining.
   / What's the secret to drilling through 1/4" angle iron? #97
Sure, putting the vise on takes 2 minutes. Which may be good for most things. But for precision you need to get out the dial indicators and make sure you are parallel and straight. Adds another 4 or 5 minutes. Not to mention that most angling vises are pretty darn heavy to be moving around alot.
Squaring up isn't something that may normally be done on a fixed vise, but I have only ever used angle base vises.
   / What's the secret to drilling through 1/4" angle iron? #99
Yea, I was trying all day yesterday I think to upload photos of my garage door springs.
   / What's the secret to drilling through 1/4" angle iron? #100
Yeah theyre heavy. I too use the slide trick when I can get enuf room that way.
I seldom indicate because I am the sole user and know the setup characteristic. I find that the stance of the vise angle base is long enuf and the keying inserts fit the slots tight enuf that the 6" vise comes back w/i a thousandth on each setup. ... If Im making long cuts Ill indicate it in. Its just a matter of a few taps with a soft hammer before final bolt tightening.
,,,larry
SHOP FAN (A55745)
SHOP FAN (A55745)
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A56129)
2005 PETERBILT 379...
378900 (A54865)
378900 (A54865)
2015 Freightliner M2 106 Altec Insulated Forestry Bucket Truck (A55788)
2015 Freightliner...
2015 Ford F-750 Stellar 10628 Mechanics Crane Truck (A55852)
2015 Ford F-750...
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
