What's The Word On Washing A BX
   / What's The Word On Washing A BX #11
If you wash it with the MMM on, run it for at few minutes afterwards to dry any water that has gotten in and around the pullys to keep from rusting.
Good point. Thanks for the help.
   / What's The Word On Washing A BX #13
MOPAULY said:
I wouldn't worry about greasing after a wash unless you use a pressure washer, grease repels water, and it would take alot of pressure to push any out of the fittings. Of all the times I've washed my tractor, there was not a hint of rust anywhere on any of the pins for the FEL or BH when I pulled them.
I would not disagree at all, but since I need to grease those fittings occasionally anyway, I just always figured I might as well do it right after washing the machine.:D
   / What's The Word On Washing A BX #14
I don't think I've washed my tractor in two years out of shear fear, anyway. :eek:
   / What's The Word On Washing A BX #15
To much grease cannot hurt :D
Unless of course it's the wrong grease, but that's in another thread I started :D
   / What's The Word On Washing A BX #16
I rarely give my equipment baths. I usually just blow the dirt off with my air compressor.
   / What's The Word On Washing A BX #17
One thing that always seems to work for me is using a leaf blower to remove dust and debris, then wash but be aware dish soap will remove any wax if you wax the hood, rims and such. But anyhow after wash and rinse, use the leaf blower again to remove any excess water from under the seat, the mmm, rims, and undercarrage, then you should only need one towel for final drying.
UNUSED FUTURE MPR42 42" HYD MINI POWER RAKE (A58376)
UNUSED FUTURE...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
UNUSED SDLAND SDLGC80 ELECTRIC GOLF CART (A58375)
UNUSED SDLAND...
2010 FORD F-150 (A58214)
2010 FORD F-150...
PALLET OF CHAINS AND BINDERS (A58214)
PALLET OF CHAINS...
2012 Honda Civic Sedan (A56859)
2012 Honda Civic...
