What's wrong with this picture?
   / What's wrong with this picture? #11
Re: What\'s wrong with this picture?
The driveline looks to be installed backwards. If that is the case and it is a radial pin style slipclutch, it won't slip. Ooo /forums/images/graemlins/shocked.gifps!
Is it possibly to have a pto shaft in backwards? Does it make a difference whether the outside shaft vs inside is towards the tractor or towards the implement? Also the outer plastic protector looks identical except for the tubes-one being bigger that the other. The clutch goes at the implement end and the locking spline dohickey at the tractor end.
   / What's wrong with this picture? #13
The majority of implements have an 1 3/8" 6 spline input shaft. Your JD's PTO shaft has the same dimensions. Therefore in some cases it is possible to install a driveline backwards. /forums/images/graemlins/confused.gif From your response it sounds like you have it pr /forums/images/graemlins/grin.gifperly installed. As long as the clutch or shearbolt yoke is installed on the implement side your ready to play!
   / What's wrong with this picture? #14
wrong color on the tractor.........sorry could not resist!
   / What's wrong with this picture? #15
Can't say for sure but it looks like you have a screw in your back tire???
murph /forums/images/graemlins/smirk.gif
PRO WORKS PWFF LOT NUMBER 156 (A53084)
PRO WORKS PWFF LOT...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2001 John Deere M665 (A50120)
2001 John Deere...
