Wheel bearing grease?
   / Wheel bearing grease? #11
It's like saying something is made from "billet" aluminum. :rolleyes: Could be a 1000 series aluminum or a 8000 series or anything in between.[/QUOTE said:
Exactly. Billet is such a buzz word. What they're really saying is "we found a cheaper way to make it, so we'll call it better".
   / Wheel bearing grease? #13
Just because it has a "MIL spec" and is used on aircraft it doesn't follow it is suitable for wheel bearings. MIL(itary) spec only cites the minimum specifications needed to met the requirements for the usage that it is intended for, nothing more. It's like saying something is made from "billet" aluminum. :rolleyes: Could be a 1000 series aluminum or a 8000 series or anything in between.
True, maybe I should have mentioned that grease was used for wheel bearings on F-16's- does that pass muster?
Where do you get Kendall Super Blue wheel bearing grease?
I can't seem to find it.
   / Wheel bearing grease? #15
Aircraft wheel bearing grease is not a good grease for automotive type use.
It is designed for short quick hot landings and takeoffs. It will not hold up to constant road or farm use. Use a grease for automotive / tractor use. It is designed for long distance ground use. The additives are what makes the greases do what they are designed for. Google the 'AeroShell book" it describes the different Aviation greases, oils, hydraulic fluids, etc. Wish they has a similar one for autio type lubes.
Retired Aircraft Mechanic
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
