Wheel horse mower deck problem
   / Wheel horse mower deck problem #1
onefletch
Wheel horse mower deck problem.
I have a 1989 Wheelhorse 414-8 with a 42 inch side discharge mower deck.
When the mower tries to mow thick grass the blades slow down to a stop. I push in the clutch pedal and the blades speed up again. I Just replaced both the mower spindle belt and the PTO drive belt. No help
Any clue as to what to do next to solve this problem?
   / Wheel horse mower deck problem #2
Keep an eye on the clutch (on the side of the engine engaged by the lever). Sometimes they start slipping if not adjusted properly and will burn up if you are not careful. Also, the spring that keeps tension on the belt around the deck sheaves may be binding or weak.
   / Wheel horse mower deck problem #3
I was having the same problem with my SB 421 or rather my son was. When the grass is too high, it's just more than the mower can cut and discharge. There's just so much space under the deck. I heard my son's belt howling and I had him slow down to low range 2nd gear. Yes it's slow but it gives the mower time to do it's job. Here's some pics. http://www.dotphoto.com/go.asp?l=wedgeheaded&AID=6160685
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
WOLVERINE PT-16-01C 3PT HITCH ADAPTER (A60432)
WOLVERINE...
2018 Chevy Silverado 1500 4X4 (A61306)
2018 Chevy...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
2006 Ford Explorer 4x4 SUV (A59231)
2006 Ford Explorer...
2017 Scag Cheetah 61in Zero Turn Commercial Mower (A59228)
2017 Scag Cheetah...
