Wheel weights vs filling tires for 5103
   / Wheel weights vs filling tires for 5103 #11
I live in Northwestern Florida and I use water in my 990's tires. Most people around here have there tires filled with water, heck my dealer did it free when I bought the tractor without me even telling him to.
   / Wheel weights vs filling tires for 5103 #12
Aha, I knew it!
   / Wheel weights vs filling tires for 5103 #13
I can't quite figure out why tractor makers don't offer a "heavy wheel" option when you purchase.
Conceivably one could design a wheel with weight built in and I sure as heck would have opted for it if I had the choice.
   / Wheel weights vs filling tires for 5103 #14
Easy to do. On larger tractors, there are usually two types of wheels. One is a steel wheel like these tractors do. The other is a cast wheel. You can add weights to both. I use both liquid and weights on my 5000 series tractor.
   / Wheel weights vs filling tires for 5103 #15
For a 5103, any suggestion on how much weight to add. Will be using box blade, FEL, and shredder.
   / Wheel weights vs filling tires for 5103 #16
125 pounds per PTO HP with 75% on the rear wheels.
At least that's what the gentleman that worked for Deere on here told me.
   / Wheel weights vs filling tires for 5103 #17
Yep, go for 125 lbs/ PTO hp as he said. If 2wd, put 70% on rears, if 4wd, use 60%. You may need more on the rear to offset the FEL. Your operator manual covers it too. For these type applications, you can go above the 125 lbs figure.
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
AGT Hot Water Pressure Washer (A57453)
AGT Hot Water...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
7ft Rotary Cutter (A57454)
7ft Rotary Cutter...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
