Ballast Wheel weights
   / Wheel weights #1
gvw
Central mountains of Colorado
JD4700
Cowboydoc! As I recall somewhere in a seperate post you indicated that you had 600 lbs of wheel weights on you 4600. How did you acomplish that? My dealer is indicating that the weights come in 100+lb increments - did you stack 3 per rear wheel? Would you still do that? Your thoughts please.
GW
   / Wheel weights #2
gvw,
Yes mine are stacked three per wheel. I haven't had any problem with it all and yes I'd do it again. Dealer says you can go three on each wheel no problem. I lift 2000 pound round bales with mine and needed all the weight I could get. I probably should have gotten a bigger tractor but I had the massey and I wanted something smaller like the skidsteer that I could get in and out of my alleys, stalls, and pens for the animals. This little thing works great. I couldn't be happier. The dealer tryed to talk me into the bigger tractor too but I stayed with this one and am glad that I did. It does far and above what they say it will do and it doesn't even act like it's working.
   / Wheel weights
Cowboy - can't remember - do you have R-1' or R-4' tires ?? Also - what wheel/rim setting did you wind up with?
GW
   / Wheel weights #4
GW,
I have the R4's and I went with the widest setting that I could go on mine. I have alot of hills and needed the stability and I needed the room to put chains on. I'm not sure what you would call the setting or the width. I can measure when I get home tonight if you want though.
   / Wheel weights
Thanks for offering to measure but I can wing it - I'm not going to set mine all the way out - will go about 3/4 of the way or I think it is shown in the manual as position 4. Thanks again from the bumpy country.
GW
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
