When did Jinmas get better?
   / When did Jinmas get better? #11
Thanks Greg, It sure seemed the rubber hose I replaced carried fuel, as it was leaking/pumping fuel when the engine was running and no leaks when not running
Thanks for the info,,
Rick
   / When did Jinmas get better? #12
might a been the fuel return line hose to the fuel tank, instead of crankcase ventilation hose Ed
   / When did Jinmas get better? #13
Well, the fuel return lines are near the valve cover. But they don't go into it. Steel lines carry pressurized fuel up to the injectors (near the valve cover). But the injectors don't ever use all the fuel delivered. What's not used for one combustion cycle is carried back to the tank on those thin black hoses. The fuel just keeps making a loop. So maybe it was a piece of return hose you're talkin' about. If true, then yes. They may look braided outside, but they're rubber inside.
//greg//
   / When did Jinmas get better? #14
Hello All,
Don't mean to hi jack your post, but if my Jinma motor is a 395 and an EPA Motor, am I good with the new fuel?
Thanks,
Rick
Better to add an additive to your fuel such as Power Service. The problem with ULSD is the reduced lubrication of the top end of the engine. I guess the newer diesels have hard valves and seats.
Anyway, Power Service additives do lube the top end. A quart bottle goes quite a ways and should last you a season.
Make sure you read the instructions when adding the Power Service (or what ever you use) to the fuel.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2022 Cub Cadet Ultima ZT1 54 in Lawn Mower (A53117)
2022 Cub Cadet...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Drop Deck Equipment Trailer (A51692)
2012 Trail-Eze...
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
2008 Doosan Mega250-V Articulated Wheel Loader (A52377)
2008 Doosan...
