When do you change your oil?
   / When do you change your oil? #11
I change mine every fall, use Rotella. I put around 70 hrs a year on my 4200.
M.D.
   / When do you change your oil? #12
Every 100 hours just as the manual says. I put two hundred hours a year on my tractor.
   / When do you change your oil? #13
Every 75 hours along with the filter in my DK45. Running Rotella T Synthetic 5W40.
   / When do you change your oil? #14
I change mine by the manual but I think it varies from model to model, depending on the engine size and amount of oil in the system. I know my B2400 is every 100 Hours and the L4740 is every 200 hours. The M5700 at the farm is every 300 hours. In all cases and for my particular usage, it means that the oil and filter get changes at least once a year.
If it makes you feel happier changing the oil every 100 hours, irrespective of what the manual says, then go for it. It's all about buying peace of mind and the additional cost isn't that much.
   / When do you change your oil? #15
My b2400 manual says to change the oil every 100 hrs and oil and filter every 200 hrs. I put about 100 hours a year on it and change oil @ 50 hrs and oil and filter @ 100 hrs. I use Rotella or Mobil 15-40 dino. I don't want to go as long as recommended for syn so I use dino and change more frequently. Don't find it an economic burden to change oil twice annually and filter once annually.
Bruski
   / When do you change your oil? #16
I agree with amigauser
Not good to let oil sit too long in the motor, not matter how many hours you've used the machine. I understand the oil's properties can change.
As has been said a million times "cheap insurance".
Joel
   / When do you change your oil? #17
I change at the interval recommended in the Owner's Manual, or annually, whichever comes first. In fact, all of my manuals list a usage interval and a time interval, i.e. "every 300 hrs or 1 yr, whichever comes first."
   / When do you change your oil? #18
hey buddy on my 4105 deere they recomend to change your oil at 200 hrs. when new then a good friend and very good hobby farmer changes his oil on both tractors every fall depending on how much use your tractor gets in a yr. if doing some serious haying you need to change more often;)
   / When do you change your oil? #19
hey there,
like the John 14:6!! I just did my 50 hour oil and transaxle oil on an X500JD and I think my manual said to do again at 200 hours
   / When do you change your oil? #20
some ag tractors are pushing the hrs up tp 300 now..I just change all the motor oil at 150hrs which generally is 2-3 times a year.. rear end oil at 1000hrs and hyd oil maybe a few of times in a machines lifetime unless there are visible problems or a repair requires draining...all filters other than engine at 1000hrs..
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
Case 1020 25ft Draper Head (A55301)
Case 1020 25ft...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2015 CATERPILLAR CT660 TANDEM AXLE DUMP TRUCK (A54313)
2015 CATERPILLAR...
