When is "Free" scrap metal not a good deal???
   / When is "Free" scrap metal not a good deal??? #11
As for rust removal, plastic bucket/tub/whatever and vinegar works great for smaller pieces. Have to let it sit in there a few days and most of the crap will brush right off. Buying vinegar at Costco is cheaper than buying it at WallyWorld.
   / When is "Free" scrap metal not a good deal??? #12
I'm very, very green to welding. Any other suggestions for where I might get my hands on "scrap" metal? Need a lot to practice on and to possibly use for projects and artwork.
   / When is "Free" scrap metal not a good deal??? #13
for some light angle Iron I have gotten some bedframes from the dump and also quite a pile behind the bed and matress store. I asked tha manager first.
   / When is "Free" scrap metal not a good deal??? #14
If you have any metal fab shops around they might sell you their scraps or "drops". You really want to avoid galvanized though.
I know what you mean, I've been "learning" with a lot of rusty junk around the farm and that gives varying results. Some of it is so deeply rusted that it probably costs more in grinding disks than it's worth! My performance is so much better when I work with new steel.
Right now I'm cutting up an old wrecked horse trailer for the metal in it.
Ken
   / When is "Free" scrap metal not a good deal??? #15
Scrap the rebar and cable for sure....
The rusted rebar is not good for concrete work and the cable is not safe.
Fyi, The scrap value on theses is generally lower.
Why do you say that?
   / When is "Free" scrap metal not a good deal??? #16
Guys,
I have already hauled over 4,000 lbs of various kinds of iron, aluminum, and copper wires to the scrap yard for cash, but now I am getting down to the good stuff I suspect. I have a large assortment of chunks of angle iron, steel cable, iron pipe, and maybe some 1/2" bar stock, some rebar (some is bent).
ALL of it is rusted heavily and has all been exposed to elements for like 6 or more years. Some of it is literally buried in my yard and I keep unearthing it.
The scrap yard pays top dollar for "clean" scrap iron in up to 4' lengths...
Is it smarter for me to sell it all or should I find a way to keep it, and how do I clean up the heavy rust, and how do I store it?
Thanks in advance,
David
You can use rust converters like Gemplers to restore heavily rusted steel
Gempler's Rust Converter Success Stories | Gempler's
Unless you need the money from the scrap dealer, I'd keep a half ton or so of that scrap for miscellaneous use as ballast on your tractors and implements.
   / When is "Free" scrap metal not a good deal??? #17
It's sounds like the Gempler's Rust Converter leaves a protective coating on the rusty metal. That would probably have to be removed before welding. It also doesn't remove any of the rust and that's not ideal for welding.
Bottom line, this sounds more like a protective coating/sealer rather than what is needed to clean up rusty metal in preparation for welding.
Ken
   / When is "Free" scrap metal not a good deal??? #18
Ken
Cleaning up rusty metal for welding is done with an angle grinder. I don't really know if there's any better way. The rust converter stuff is what you use after you have welded to prep for paint.
   / When is "Free" scrap metal not a good deal??? #19
I agree. But flusher and Gempler's call it a "rust converter" that restores. I don't think it converts the rust, it just seals it.
Ken
   / When is "Free" scrap metal not a good deal??? #20
Ken
No, it actually converts the rust by "unoxidizing" it. I doesn't make it back into structurally sound steel, but it converts it into a stabile substance that won't continue to corrode the adjacent metal.
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
7' FLAIL MOWER (A58375)
7' FLAIL MOWER...
2001 CASE 570LXT Box Blade (A59213)
2001 CASE 570LXT...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
SDLD25 MINI DUMPER (A58216)
SDLD25 MINI DUMPER...
