When Safe to Move Ballast Box with Fresh Concrete
   / When Safe to Move Ballast Box with Fresh Concrete #11
I don’t disagree, so long as he doesn’t use it for a rear mounted battering ram. I was hedging a bit so the 28 day gang didn’t crucify me.
They can be heartless. ;)
   / When Safe to Move Ballast Box with Fresh Concrete #12
My 28 day was based on using concrete structurally and most people that use bag mix use too much water. For weight in a box you are good the next day
   / When Safe to Move Ballast Box with Fresh Concrete #13
At a glance your answer was technically correct. Upon further inspection it becomes apparent the concrete mix is contained and simply weight. :)
   / When Safe to Move Ballast Box with Fresh Concrete #14
For our pours at work we have test cylinders broken at 7 and 28 days. Nearly all cylinders have compressive strength at greater than design mix for the 7 day break.
   / When Safe to Move Ballast Box with Fresh Concrete #15
My blob of concrete stayed in the form for a bit over two weeks. Estimated weight - 480 pounds. There is a short lifting chain - center, top of the blob.
   / When Safe to Move Ballast Box with Fresh Concrete #16
What type of form did you use for that Oosik? Wood or steel?
Also..... what brand/model vibrator?
   / When Safe to Move Ballast Box with Fresh Concrete #17
Fried - the form was plywood with 2x4 edges to hold it all together. Vibrator - you gotta be kidding. This was strictly a slop and drop job. As you can see - over the years the edges have suffered somewhat. But it still works.
   / When Safe to Move Ballast Box with Fresh Concrete #18
Having built a half a billion dollars worth of public schools where we were required to probably test 10,000 cylinders, approximately 9 out of 10 reach 100% of design strength at 7 days. Twentyeight day strength usually hit 135 to 175% of design strength.
Of course, this was not Quikcrete.
   / When Safe to Move Ballast Box with Fresh Concrete #19
I WAS kidding !!!
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A55852)
2018 Ford F-250...
UNUSED FUTURE 72" CLIP ON FORK EXTENSIONS (A57193)
UNUSED FUTURE 72"...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
