When to change to synthetic?
   / When to change to synthetic? #11
Once again.......
Lifted from another thread, in the Ferrari forum.....don't know if it's true or not, reads interesting.....
"A bit of information directly from a shell engineer. Note that at the end he states that the base stock in Rotella T 5w-40 synthetic (available at walmart for $14 a gallon) ,Shell Helix(Ferrari dealer $16 a quart), and Ferrari's formula 1 oil cocktail is the exact same thing minus different additives. Is the highly rated Rotella T synthetic 5w-40 another credible alternative to overpriced Helix? After all, the Rottela t does meet and far exceed all current testing standards (SL, Sj, etc) not to mention an incredible viscocity index of 178 degrees c (mobil 1 0-40 is 168 c).
"It is true that ROTELLA T Synthetic is Group III (not PAO) based, but you must keep in mind that not all Group III base oils are created equal. ROTELLA T Synthetic is made with Shell's XHVI base oil, which unlike other Group IIIs does not begin as distilled crude oil, hence of all Group III base oils, XHVI is truly the only one that can legitimately be called "synthetic." XHVI is a wax isomerate, meaning that it is made from the slack wax removed from distilled crude in normal solvent dewaxing. This slack wax is catalytically transformed (isomerized) and hydrofinished into a chemically pure base oil which rivals PAO in virtually every category. There are other "synthetic" oils out there based on Group III, but Shell's is unique in that it uses XHVI base oil. Chevron and Petro-Canada produce Group III base oils that come close to XHVI, but even though these oils are all hydroprocessed and utilize the same type of isomerization technology employed in the making of XHVI, they are not the same thing. Only XHVI is made from pure petroleum slack wax and its CAS number is 92026-09-4. The CAS number for the more typical all-hydroprocessed Group III base oils is 64742-54-7. If you want to know what your "synthetic" oil is made from, take a look at the MSDS and look for these numbers. (The CAS number for PAO is 68037-01-4).
In brief, don't be so quick to dismiss Rotella T Synthetic as just another "synthetic pretender." It's made with the same base oil as Shell's Helix Ultra, and everytime you see Ferrari win a Formula 1 race, that's the oil in the engine.""
   / When to change to synthetic? #12
IH3444 said:
Once again.......
BUT...if it passes ALL testing...and meets or exceeds any and all requirements...it doesnt matter if its made up from gound up monkey gizzards!
Dinosaur fat based; PAO based; CEO based; UPS based or even PDQ based...it either meets the requirements or it doesnt!
   / When to change to synthetic? #13
I'm actually going to try to change all the fluids to synthetic.
Hmmm.. somewhere, maybe in here, I was reading a thread about problems with water contamination in synthetic gear lube (I think - too many forums/too many threads/not enough memory :confused:). Something about an ingedient in there that attracted moisture, and if you didn't run the machine enough to get it warm enough to burn off the moisture, it caused bearing problems. Might want to research that.
   / When to change to synthetic? #14
It seems you do not and never will pull some UOA's..
   / When to change to synthetic? #15
And whats a used oil anlysis got to do with it? I change oil per a recommended sched. And if that oil exceeds the makers requirements for usage I dont need to spend as much as 5 cents haveing the used oil analyized
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
